20 Most Recent JVC Everio GZ-MG77 Camcorder Questions & Answers
This is usually caused by a failed component in the power circuit within the camera. This will require disassembly and trouble-shooting to identify and replace the defective component and can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
JVC Everio... | Answered on Jun 09, 2012
Hi, That sounds normal. Most camcorders will come on when plugged in. If you think there is still a problem go to a camera repair. Good luck.
JVC Everio... | Answered on Sep 15, 2011
The only way to get the software for your camera is to contact JVC at (800) 252-5722 or email them at the link below.
http://secure.jvc.com/consumer/forms/contactsupport.jsp
JVC Everio... | Answered on Jun 04, 2011
Video HDD recovery is possible as long as nothing has been recorded over the original images can be done fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
JVC Everio... | Answered on Sep 03, 2010
Hi, you can trythis link its brings you wheres you want to ( jvc.com/support/gz-mg77/update)
please use google it should be the firts option
on the list , cant miss.
hope that will help you
have a good day....
JVC Everio... | Answered on Mar 05, 2010
Please provide more detail in your question like why you want to add a jack as this camcorder already has AV out pin near USB port at back of camera.
What you want to plug in camcorder with that 3.5mm jack?
Thanks.
JVC Everio... | Answered on Dec 18, 2009
Are you talking about a stand alone dvd players?
If you are talking about a stand alone dvd player, that is correct they do not player .avi extension file. I know some portable dvd player can play avi extension files.
all avi extension files needs the right audio and video codec to be player. All stand alone dvd players does not and can not detect codec for you.
On the issues of dvd-r brands, Some stand alone dvd players can only play dvd+r type dvds. ck your brand of dvd disc and players, make sure they are complatible with each other.
unfortunately, with everio share station will not allow you to do it that way. You really, absolutely need the date and time on the video, you will have to capture the date and time with another device. For example, the one touch video capture vc500 will do that for you. To my knowledge, there are no software out there that can capture date and time at the moment.
JVC Everio... | Answered on Dec 01, 2009
could be that BATTERY lost its capacity to store energy , or check the contacts make sure there clean , use a Q tip and alcohol , hope it helps , AJ
JVC Everio... | Answered on Nov 04, 2009
NECESITO EL SOFWARE DE LA CAM GZ-MG77
JVC Everio... | Answered on Apr 15, 2009
Use different software.
JVC GZ Video... | Answered on Jan 08, 2018
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
JVC GZ Video... | Answered on Mar 24, 2016
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
please write the question in English.
JVC GZ Video... | Answered on Mar 18, 2016
JVC Everio GZ-MG77 Camcorder Logo
25 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GZ JVC
  • GZ JVC
Most Popular Question
camera suddenly not
  • Video Cameras
