20 Most Recent LG LMV2053 Microwave Oven Questions & Answers
Our LG did the same thing - called customer service and they told us the open and slam the door 10 times. It actually worked! It reset the switches somehow.
LG LMV2053... | Answered on Jul 16, 2017
I agree, most likely the fuse.
LG LMV2053... | Answered on Apr 24, 2014
To zig107 RE: LMV2053XX
A lot of times it's easier to set the microwave on its left side, then open the door and work on it.
That way, gravity will help you keep things in place.
Assuming this is an over the range model, you'd have to pull the oven from the wall. Refer to your installation instruction booklet for details.
If for some reason you don't still have yours, you can order it as part number 3828W5U0492 from the Pros here.
You can download the owner's manual here.
You can download the service manual by clicking the text link below the document preview on this page.
Be careful where you click on that page (which is not mine). Please follow the download instruction above.
LG LMV2053... | Answered on Jan 22, 2014
On this over the range model, you'd have to pull the oven from the wall. Refer to your installation instruction booklet for details.
If for some reason you don't still have yours, you can order it as part number 3828W5U0492 from the Pros here. They are a good source for LG parts.
ovenisturning but no heat
LG LMV2053... | Answered on May 08, 2012
Just opened mines today .... guide below is almost correct ....when you lift the cover off the bulb is shielded behind a metal box.... theres one screw that connects it to the magnotron .... take off that screw and pull out the plug with the brown and white cables that is connected to the bulb... the bulb is a T170 KEI 240v 25W on mines at least which no one around stocks so will just try and claim under warranty as 2 years labour 6 years parts... bulb has never worked just never got to opening it up ...bulb looked trashed when i took it off... element was all black and in bits rattling inside the microwave ... only use the thing for warming kids milk and sterilising bottles...
LG LMV2053... | Answered on Apr 25, 2012
you may have blown a fuse if there is no power display...the fuse unfortunately is located in control panel... it usually is either a 15 amp or 20 amp fuse... do not put a larger one in or a smaller. to test the fuse if you cant visible see it is bad you will need to ohm out and should get continuity ...if the fuse is good and you have no display most likely the pcb or board is bad.... good luck
LG LMV2053... | Answered on Jan 02, 2011
it could be a failing magnetron. common failure for these units.
LG LMV2053... | Answered on Aug 31, 2010
Lowes will post out the correct bulb for your unit if you supply the model. Putting in a non standard bulb is nit recomended.
LG LMV2053... | Answered on Sep 24, 2009
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
LG LMV2053... | Answered on Jul 01, 2009
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
LG LMV2053... | Answered on Mar 06, 2009
yep you got it in one, I must have advised about 10 people today about this. when the door is slammed the door protection circuit does not operate correctly and then takes out the mains fuse inside the unit. renove the case and locate the fuse, normally where the cable enters the unit. as long as the fuse is the correct amperage, lenght and diameter you have no problems. do not test the unit with the cover off and be careful as the capacitors can hold a lethal charge
LG LMV2053... | Answered on Feb 21, 2009
It sounds like your varistor or low voltage transformer on your control circuit board is failing.
We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
LG LMV2053... | Answered on Jul 13, 2008
You should be able to find a sub at a home improvement center like Lowe's or Home Depot.
Many models halogen lamps. You must not touch the new ones with your bare skin.
Be sure the oven is unplugged when you remove or install bulbs, as that can damage the control board. We repair them all the time for this.
LG LMV2053... | Answered on May 10, 2008
LG LMV2053 Microwave Oven Logo
36 questions posted
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
lg microwave lmv2053 developed reduced
  • Microwave Ovens
