20 Most Recent
Copystar CS-1815 Digital Copier 042DD512 Questions & Answers
"waste toner is full"
pull out your drum unit. locate green tab on the right top of unit. now, take out one screw and remove small cover on the rear, right side and empty very carefully.
hth,
razors
Copystar 1815 problem!
Are you getting black or white lines on your copies when you use the adf? When you lift the adf up and look at the copy board glass for any dirt, next look at the small piece of glass next to it. The white out is on that part or the copyboard glass. Clean it off and you should be good to go. You would get paper jams if the white out is on the rollers. If you want to clean them use a rag with very little WD-40 on it and lightly rub the white out off. Yes, I did say WD-40, it is not just for squicks... Good Luck
How do i reset Error code C6020 on a Kyocera 8030 copier
This code is a high temperature in the fuser unit. The reset process is as follows, enter 1087-1087-163-print button-execute-print button then shut machine off when the message comes up on the display. The machine should clear the code and reboot, if the code returns you will need to contact a service company for further assistance. Hope this helps.
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
1135
Paper jam in the paper cassette
