Ice maker worked for a month & than stopped/replaced part in door same thing happened...
(More)
Ice maker worked for a month & than stopped/replaced part in door same thing happened again/water not feeding into ice dispenser. Also last night back of refrigerator (bottom) was very hot to the touch. Pulled away from wall in fear it would catch on fire - is this normal? Thanks for your help!! Greatly appreciated.
We unplugged and cleaned out our refrigerator today, it was unplugged for about 1 hour. After...
(More)
We unplugged and cleaned out our refrigerator today, it was unplugged for about 1 hour. After plugging it back in, it started working fine, however the back of the refrigerator is very hot, along with some areas on the sides. The air is flowing from the freezer down to the refrigerator compartment, and the freezer is cold as normal, but the frige feels slightly warmer (due to the heat on the outside of the frige I believe). I never noticed a fan on the bottom working before so don't know if it stopped, no air is being blown out from the bottom though, but we hear the fan running on the inside and can feel the air blowing inside the freezer (even when activating the button like the door is closed etc. Finally if I unplug the unit even for a minute and plug it back in, then it will go cool like normal for about 15 minutes, but then starts to heat up again. The unit is just about 1 year old.
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Even though I have found a statement (I think it was in the LG troubleshooting FAQS on line) that the lights in the newer LFX25960 french door/bottom...
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
