Troubleshooting & Support
Hot Topics:
- ice buildup...
- drain pan
- compressor...
- noisy fan
- door left open...
- glass shelf
- lg gr
- build freezer...
- ice build lg...
- lg fridge...
- lg freezer ice...
- noise
- control board
- lg door freezer...
- ice freezer...
- lg fridge not...
- water ice taste...
- VIBRATION
- lg bottom...
- access coils
- ice accumulates...
- freezer door...
- few freezer old...
- ice freezer...
- compressor
- frost freezer
- manual
- warm
- bottom freezer...
- water leak
- View All »
Problems & Solutions
The refrigerator is running but not getting cold
you may need to have it charged with more freeon.. but chose wisely. it is expensive..
LG refrigerator model LRBC22522WW icemaker model
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
the refrigerator is not cold inside.
Do you have an error code? More than likely you have a ER FF or 6,7. The problem is you have a build up of ice that is blocking your fan....
Ice Maker
Put the ice maker through a test mode. Press and hold the sizing button for 5 seconds or so and it should go through a complete cycle. Quite...
refrigerator is not cold but
Hi, Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can...
I HAVE AN ERROR MESSAGE ON MY FRONT PANEL THAT
ice maker fan(IF)
Why is water leaking from under LG model LFX28978
cracked or misaligned drain pan usually just dirty and out of alignment from being moved
where are the error codes on the refrigerator
Does your LG have a digital display? It should be on the display somewhere. What is the Model #?http://www.ehow.com/list_6318472...
My water feed tube at the bottom of the freezer...
Instead of replacing the entire tube, have you thought about repairing the break? They sell spice kits at most home supply stores like...
on my LG top freezer
The drain in the freezer behind back lower panel needs opening. You can see it at the bottom of the back panel underneath the evaporator...
Refrigerator model GR-B247WV Bottom of freezer
Hi, You may have a blocked drain. Therefore when your fridge goes into a defrost cycle, the melted water usually travels down a drain hole...
Bottom Freezer model, LFD23860st, Freezer
Our refrigerator stopped working after
The water inlet tube in my LG GR208DVQA
Hi DavidT-FR, If I can advice you first to check the Inlet Valve to see if it is indeed faulty. Remove the Inlet Valve but keep the pipe on...
LG express cool no frost
I had the same problem - repairman was just here - it was the defrost motor was burnt - the freezer had frost buildup behind the panel,...
Unsolved Problems
drain line is frozen and frost all over interior...
Service man says all other parts are working...door seal good, defroster working, and fan working. What would cause the...
MY LG GR-232SBF
MY LG GR-232SBF FRIDGE FREEZER NEVER SEEMS TO GET AS COLD I LIKE IT BUT I HAVE MISLAID MY INSTUCTIONS AND NOT SURE...
Our ice machine is not making ice. We checked all
Our ice machine is not making ice. We checked all of the water lines and there is no blockage. It dropped ice one time...
LG LRFD2585OST making noise all
LG LRFD2585OST making noise all of a sudden , when I open the doors it stopped. Removed a bunch of ice from rear coils.
there is a bad smell
there is a bad smell comming from our lg fridge the fridge has a bottom freezer the smell seems to come from the...
The ice maker is not
The ice maker is not working. We tried to run it through it's cycle by holding down the sizing button for 5 seconds, but...
my lg fridge double door
my lg fridge double door 7 years old is smelling bad . what to do ?h_
Manuals & Guides
TopDo you have a manual for LG LRBC22522 Bottom Freezer Refrigerator? - Upload it to FixYa!
Upload a manual for LG LRBC22522 Bottom Freezer Refrigerator
Specifications
TopKey Features
Full Product Name:LG LRBC22522 Bottom Freezer Refrigerator
Type:Bottom Freezer
Total Volume:22.4 cu. ft.
Fresh Food Volume:15.5 cu. ft.
Freezer Volume:6.9 cu. ft.
Ice Maker:With Ice Maker
Installation:Free-Standing
Total Number of Shelves:4
Fresh Food Compartment
Fresh Food Shelves / Bins:Gallon Storage
Fresh Food Shelves / Bins:Vegetable Bin (Controlled Humidity) x 2
Fresh Food Shelves / Bins:Snack Drawer
Fresh Food Shelves / Bins:Dairy Center
Fresh Food Shelves / Bins:Spill Proof Shelves
Fresh Food Shelves / Bins:Split Shelves
Shelf Material:Glass
Light:Yes
Freezer Compartment
Shelve / Bins:Bin x 2
Ice Maker
Dispenser:Water
Dispenser:With Water Filter
Convenience
Exterior Color:White
Energy
Energy Efficiency:Energy Star Compliant
Dimensions
Overall Depth:33.25 in.
Overall Height:69.5 in.
Overall Width:32.88 in.
What's your problem?
Fix-O-Meter
5,812
5,812 people have viewed this product
- 33 people asked about this product.
- 6 people found solutions for this product.
- 3 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
