20 Most Recent LG WM2042 Front Load Washer Questions & Answers
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
LG WM2042 Front... | Answered on May 07, 2016
It sounds like you are over-filling the drum with water. Check the fill switch. If the fill switch is bad, it will not stop filling with water.
LG WM2042 Front... | Answered on May 10, 2015
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
LG WM2042 Front... | Answered on Aug 26, 2011
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
LG WM2042 Front... | Answered on Aug 06, 2011
For my washer it means the drain hose is bent/ clogges or the drain filter is clogges
LG WM2042 Front... | Answered on Mar 03, 2009
Before ordering a new control board, check the wiring harness to make sure there are no breaks in the wire from the water valve to the board.  If everything checks out, replace the board.  The board is not that hard to replace and all the wire connectors are not confusing.
LG WM2042 Front... | Answered on Dec 16, 2008
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
LG WM Washing... | Answered on Dec 27, 2017
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
LG WM Washing... | Answered on Apr 25, 2017
http://www.lg.com/au/support/support-product/lg-WT-H9556
LG WM Washing... | Answered on Mar 29, 2017
There is no need to raise the water level. all modern washers automatically add the amount of water needed to wash the amount of clothes that you put in, I could explain how, but it will put you to sleep. rest assured these machines pretty much look after themselves. I would be more interested to know why you think it needs more water, are you having rinsing issues? wash quality issues?
LG WM Washing... | Answered on Oct 18, 2016
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel.
Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
LG WM Washing... | Answered on Aug 15, 2016
If you wish to get some details; check the site linked here. Pull up older posts........
http://electro-medical.blogspot.com/
LG WM Washing... | Answered on Jun 12, 2016
take the back off
see if the water pump making that noise or is broken
should look something like this one
LG WM Washing... | Answered on May 18, 2016
LG WM2042 Front Load Washer Logo
13 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
lg washing machine keeps stopping says
  • Washing Machines
