I have tried to connect my lg tv to my dell laptop with hdmi. The picture is there but no sound. I...
(More)
I have tried to connect my lg tv to my dell laptop with hdmi. The picture is there but no sound. I have know the hdmi cord works with sound and so does my computer since i plugged it into a samsung tv and it worked just fine. I did not have to change any settings or anything. Please help because both lg and dell will not help me out!
the tv turns on then off straight away and continues to do so, only moved it into another room it...
(More)
the tv turns on then off straight away and continues to do so, only moved it into another room it ran for maybe 3min, please heeeelp
occasionally when Viewing channel 7 channels eg. 6,60, 61,62,63 the Tv will turn off and on...
(More)
occasionally when Viewing channel 7 channels eg. 6,60, 61,62,63 the Tv will turn off and on repeatedly until i quickly change the channel to a non channel 7 station. ANy ideas?
Whilst watching football the my screen turns blue and I have to turn the tv on and off to get the...
(More)
Whilst watching football the my screen turns blue and I have to turn the tv on and off to get the proper picture back. I have also noticed speckles appearing on the screen recently. Can you help Many Thanks Paul
the stanby light red when you switch on via the remote the light turns green but they is no picture...
(More)
the stanby light red when you switch on via the remote the light turns green but they is no picture or sound
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Michael from Queens, New York Purchase a LG 42" HDTV connected it to Direct TV service, while on the regular service no problem, but went to...
written by mwv2001
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
Specifications for LG 42PX4DV 42 in. EDTV-Ready Plasma Television
Key Features
Screen Size
42 inch
Contrast Ratio
10,000:1
Digital TV Standard
EDTV-Ready - Requires separate receiver to view EDTV signals. · EDTV-Ready
Flat Panel Type
Plasma
Display Resolution
852 x 480 pixels
Display Capabilities
Built-in Tuner
NTSC · PAL · SECAM
Digital TV Standard
Broadcast Format Displayed
480p (EDTV) · 480i (SDTV)
Interpolated Aspect Ratio
4:3, 14:9
Image Quality
Comb Filter
3DYC / 3D Digital
Brightness
1500 cd/m??
Output Color
10700 million colors
Viewing Angle
160
Adjustable Color Temperature
With Adjustable Color Temperature
Remote Control
Remote Control
Standard
Audio Features
Audio Type
Virtual Surround
Audio Leveler
With Audio Leveler
Technical Features
Picture in Picture
With PIP
Parental Control
Proprietary
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Composite x 1 · RF x 1 · Audio (Mini Jack) x 1 · S-Video x 1 · Component x 1 · Audio (RCA) x 2 · 1 x D-Sub (RGB PC) · 1 x RS-232C · HDMI x 1 · 21-pin Scart x 3
