20 Most Recent LG 32LC2D Television Questions & Answers
2answers
I have an older model LG TV that gets a perfect picture and sound for about 15-20 minutes, then goes to a black screen with various lines and no sound?
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
11/13/2016 4:29:24 AM • LG 32LC2D... • Answered on Nov 13, 2016
3answers
LG32LC2D - Sound slow to start
This is indicative of a bad main board that will need replaced. For this model make sure the repair person has the full product code (from the back of the unit) so that they can get the correct main board ordered (there are multiple versions depending on the product code). Hope this helps.
11/13/2016 4:22:55 AM • LG 32LC2D... • Answered on Nov 13, 2016
Why my tv is taking to much time to show the escren
1/24/2016 9:33:50 AM • LG 32LC2D... • Answered on Jan 24, 2016
Screen went blank, cannot get TV to respond. turns
CAPACITOR C208 BAD 680UF 16V ON POWER SUPPLY BOARD.
Credit to: http://www.repairworld.com/
1/8/2015 11:06:12 PM • LG 32LC2D... • Answered on Jan 08, 2015
manual
Why does the screen go black and sound go off and I get an intermittent a chattering static type noise? When I turn TV off and on again the sound and picture sometimes return for a few minutes then ho
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
9/2/2014 6:55:49 AM • LG 32LC2D... • Answered on Sep 02, 2014
2answers
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
8/18/2014 9:45:39 PM • LG 32LC2D... • Answered on Aug 18, 2014
0answers
0answers
0answers
Black lines
Be the first to answer 1/15/2014 3:48:54 AM • LG 32LC2D... • Posted on Jan 15, 2014Be the first to answer
0answers
Lg problems
Be the first to answer 1/12/2014 3:37:35 PM • LG 32LC2D... • Posted on Jan 12, 2014Be the first to answer
NDIZET NORMAL MENU NORMAL FUTET NE KERKIM DHE
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.Translation option is there, can be pulled out by the right side bar.
10/28/2013 12:49:46 PM • LG 32LC2D... • Answered on Oct 28, 2013
0answers
Reset tv factory
Be the first to answer 10/27/2013 2:29:21 PM • LG 32LC2D... • Posted on Oct 27, 2013Be the first to answer
Tv code blink
If you wish to know more about the blinking codes to TVs, and others, check the site linked here. It blinking codes details to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
10/3/2013 4:09:58 AM • LG 32LC2D... • Answered on Oct 03, 2013
Televison & Video Logo
100 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
ndizet normal menu normal futet ne
  • Televison & Video
