Hello, my LG 42PX3DCV 42 in. EDTV Plasma Television will not turn on. Last week the power went out...
(More)
Hello, my LG 42PX3DCV 42 in. EDTV Plasma Television will not turn on. Last week the power went out and ever since it wont turn on, its like its unplugged. Whats wrong?
I have a 42PX3DCV and the screen stopped working. I was watching the TV, the screen became kind of...
(More)
I have a 42PX3DCV and the screen stopped working. I was watching the TV, the screen became kind of fuzzy, and then a loud pop and the screen went black. Now have sound but no picture.
tv cuts out when the picture on the screen is a dark part, like if i walk into shadows on a video...
(More)
tv cuts out when the picture on the screen is a dark part, like if i walk into shadows on a video game
I have a Vizio P42HD Plasma TV. When a first got it, It had to be repaired. Replace the power board ...
(More)
I have a Vizio P42HD Plasma TV. When a first got it, It had to be repaired. Replace the power board believe. Now 1-1/2 years later, It has another problem. Periodically the picture loses resolution and has a grey grainy look; and what should be the dark areas have almost a negative bright grainy look. Any ideas of whats going on?
i was playing ps3 on my vizio plasma HDTV.. after three hours of playing the image disappeared and...
(More)
i was playing ps3 on my vizio plasma HDTV.. after three hours of playing the image disappeared and the tv froze it did not turn off manually nor with remote control. i had to unplugg from outlet, then plugged back in and the tv turns on but cant turn off and i still dont have image? can you help?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Michael from Queens, New York Purchase a LG 42" HDTV connected it to Direct TV service, while on the regular service no problem, but went to...
written by mwv2001
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
