There is a blue area right in the top middle of the screen and runs down to the bottom fading...
(More)
There is a blue area right in the top middle of the screen and runs down to the bottom fading slightly as it goes down
picture fades to static after about 10 minutes, sound stays on. sometimes picture comes back on,...
(More)
picture fades to static after about 10 minutes, sound stays on. sometimes picture comes back on, then fades out to static again. what's wrong?
I have a blue blob that is taking over my LG RU52SZ30 TV - it is getting bigger. What is the LT fix...
(More)
I have a blue blob that is taking over my LG RU52SZ30 TV - it is getting bigger. What is the LT fix and how long would the fix last?
LG 32LC7D turns off and will not turn back on. It happened about 6 weeks ago and then after 3 days...
(More)
LG 32LC7D turns off and will not turn back on. It happened about 6 weeks ago and then after 3 days it came back on by itself.. it was working fine but the same problem has happened again. Now on day 2 with no picture/lights/sound.
My LG lcd rear projection TV recently went out we thought that it was the light bulb, but when i...
(More)
My LG lcd rear projection TV recently went out we thought that it was the light bulb, but when i replaced it it still did not turn on. When i try to turn on the TV the red light will flash yellow and i will hear a few clicking noises and then the light will go back to red. The model # is RU-52SZ30. Can you please get back to me with what to do?
you stated a solution about soldering? can you give me more detail thank you. How do I get to the...
(More)
you stated a solution about soldering? can you give me more detail thank you. How do I get to the board I need to retouch? Do I need Solder? thank you email onesandzerosrock@hotmail.com
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
