Tv will scroll whit light and then after a while turn red while never turning green. There is a...
(More)
Tv will scroll whit light and then after a while turn red while never turning green. There is a second blinking red light that goes away after tv shuts itself down
I have no analog video, sound does come through. D-TV channels come through on coax input, but I...
(More)
I have no analog video, sound does come through. D-TV channels come through on coax input, but I cannot not get video through any of the coax or Yellow video inputs. HDMI and component work, as well as digital TV channels. Possible lock, but don't have a remote and no code. Is there a reset to default procedure?
when i change inputs from the remote the sound wouldnt work. i hit it again and it worked this went...
(More)
when i change inputs from the remote the sound wouldnt work. i hit it again and it worked this went on for some time occasionally. now im not getting sound at all through input 1 and and iinput 2 works sometimes.
when i first start tv its good for awhile then will shuting down,red light shuts off and white light...
(More)
WHEN I FIRST START TV ITS GOOD FOR AWHILE THEN WILL SHUTING DOWN,RED LIGHT SHUTS OFF AND WHITE LIGHT BAR WILL RECIPOCATE UP 7 TO 14 TIMES,IT WILL DO THIS TILL IT GETS WARM THEN TV IS GOOD
The sound just stopped working. I even plugged headphones in to the headphone jack and still no...
(More)
The sound just stopped working. I even plugged headphones in to the headphone jack and still no sound is coming from the tv. It is not muted.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
