20 Most Recent Marantz SR4500 Receiver Questions & Answers
You can do it by using the arrow keys at the front panel.Study the user manual before that.
Marantz SR4500... | Answered on Oct 14, 2013
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.In this case I think that some capacitors are faulty as when the set is put on it charges on to make the amplifier work. Possible fault in the protect circuit or preamp.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Marantz SR4500... | Answered on May 11, 2011
if your amp doesnt have air vent fins on the sides you shouldnt have any problems with overheating
Marantz SR4500... | Answered on Oct 06, 2010
Click here for Comcast Remotes Five Didgit Codes hope it works for you did for me.
Marantz SR4500... | Answered on Jan 24, 2009
If you are using AV cables from your TV for movies and a different hookup for the X-Box would explain that the relay for the sound inside your unit may have blown from being overloaded or faulty. Should be an easy fix at a trusted electronic service place.I am not sure if your system has a manual reset button underneath or on back, but you could look for a tiny hole with reset on it or a red button. It may save you a trip to the doc.
Marantz SR4500... | Answered on Nov 11, 2007
Some amps offer the entire signal out, to a processor, like a sub woofer. That system will shave the parts of the signal that it needs, ans passes the rest back to the amp for it to process. Your amp will not have to contend with the burden of processing the removed portion of the signal. Supposed to be more efficient and "truer".
Marantz Audio... | Answered on Aug 31, 2018
Press the set up button on the remote and navigate till you find the update option.
Marantz Audio... | Answered on Aug 26, 2018
Fuzz and pop sounds like bad capacitor or blown transistor.
Best to take it back to service center.
While there, throw your toys out of the cot, explaining that they did a 'b*m' job.
Marantz Audio... | Answered on Jul 15, 2018
Marantz SR4500 Receiver Logo
16 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
martantz sr 3000 any remote codes
  • Audio Players & Recorders
