20 Most Recent
XFX nVidia GeForce 210 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Exp Questions & Answers
When i start max payn 3 my scren show blu screen
This is usually a sign that there is a hardware or driver problem. Try removing the latest hardware that you have fitted since the system was working properly. And I would also suggest that you check that the graphics card you have is good enough for the game you are trying to play. There is a great site that will tell you if your system is capable of playing just about any game. it is called "can i run this" Follow the instructions on the website and search for the game you wish to run.
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
No sound xfx one
You must set up port in drivers and in windows
analog for speakers and headset, or
digital for hdmi to tv speakers
How to repair msi vr320x with no display?
Does both the port not giving you display did you check the memories is it all fine set also the power you have connected it properly try it in different machine check the PCIE Volts which slot is suitable for your Card on your motherboard.
try the display cables and cooling all ok than i am afraid you need to send it to a workshop or you can fix if you know chip level work so there is An IC if fails or leak it does not give any out put so you need to change that.
Nvidia 9600 gt
Maybe you have set the view to large icons in properties.
