20 Most Recent EliteGroup Intel Pentium 4 Processor 506&ECS P4M800-M7 Motherboard (506P4M800M7) Questions & Answers
HI
Please check your processor is supporting in your motherboard. and check the RAM also its fix properly some time if u not fix the RAM properly the same ERROR is coming..
Good Luck
EliteGroup Intel... | Answered on May 11, 2011
go to your computer manufacturers website
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=91
good luck!
EliteGroup Intel... | Answered on Feb 27, 2011
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps don't forget to vote
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
EliteGroup Intel... | Answered on Feb 01, 2011
hi raz, i can help you , i think your old drive is been corrupted just download drive from the given link
just copy and paste the link you can see DRIVE heading click it and scroll down you can see On-Board Audio download your XP version AUDIO drive and install it. surely your AUDIO drive will work like before
Good luck ! if you think your problem solved don't forget to rate
EliteGroup Intel... | Answered on Jan 01, 2011
Hi!
There are 2 revisions for your motherboard... Download the driver that match your motherboard revision:
1. P4M800-M7 (V3.1)
2. P4M800-M7 (V1.0)
Regards,
Pelu.
EliteGroup Intel... | Answered on Sep 19, 2010
This motherboard let you onboard audio device.
So now you have to install your driver of your audio device to make sound.
To install insert your diskette in your CD-ROM which has come when you bought a new PC or new motherboard.
Your motherboard supports 6-channel audio codec device which is inbuilt.
EliteGroup Intel... | Answered on Apr 09, 2010
You don't get a sound driver based on the processor. You need to find the sound device in your computer and give us the information found on that device. The processor is a completely different thing.
EliteGroup Intel... | Answered on Jan 24, 2010
DO you have a stuck key on the keyboard? The repetitive beeping that doesn't quit is keyboard.
EliteGroup Intel... | Answered on Dec 07, 2009
CPU or motherboard would be my guess. Try resetting the bios with the onboard jumper. Also could be a memory problem.
EliteGroup Intel... | Answered on Oct 08, 2009
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:- http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
EliteGroup Intel... | Answered on Jun 13, 2009
have you updated your bios on your motherboard and windows vista automatically updates and find drivers so its ever not compatable or maybe your ide cables may be broke or the jumper is not set to master or cable select so could you write back to me at shaunhook1@live.com or post in forum if u have checked all the above and still cant solve the problem
EliteGroup Intel... | Answered on May 01, 2009
pls send me mercury mother board driver of MODEL NO: PNMCP73V V1.0
EliteGroup Intel... | Answered on Apr 17, 2009
You can use Winflash to upgrade the motherboard BIOS or during boot using text or character driven interface . These utilities can be downloaded free of cost from the mobo manufacturer website. BUT MIND YOU IF YOU DO NOT FEEL CONFIDENT ENOUGH OR NOT SURE OF THIS PLEASE DO NOT TRY THIS AS ANY ERROR IN THE PROCESS OF UPGRADING MOTHERBOARD BIOS WILL RENDER THE THE MOTHERBOARD USELESS. An 8x AGP PRO Card should work without hitches on tis mobo
EliteGroup Intel... | Answered on May 06, 2008
phalitao, you need to check you're power supply it may be bad.
No PC or notebook will boot without memory. However in your case I would recheck all power connections from the power supply to the board. Remove & reseat all power connections.
Please use you're manual help guide you. Also on the back of you're power supply (on most PSU's), there is a Red slide switch. Please make sure it is set to 115v & not 220v. After all this checking & you do not see life from the board, suggest you replace the power supply with a min wattage of 400w. Or borrow a PSU of 350w or better.
Please post back with you're findings.
In order to stay within this post do this.
How to repost more questions for same problem.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Answer quwstions from you're tech & add more information.
Good Luck!
Mike
EliteGroup Intel... | Answered on Apr 22, 2008
Computers & Internet Logo
25 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
used audio device before but
  • Computers & Internet
