20 Most Recent EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Questions & Answers
Hi
You don't really ask a question here but the link below takes you to a page on the manufacturer's website where you see specifications, download manuals and drivers (depending upon OS), CPUs supported etc.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=530&MenuID=24&LanID=0
All I can do is suggest that you try this page and if it doesn't help, repost with a specific question.
Cheers
EliteGroup ECS... | Answered on Aug 27, 2014
Unistall & then reinstall sound driver.
EliteGroup ECS... | Answered on Jun 23, 2014
I have found the manual for your P4M800PRO-M V2.0 Motherboard. The connection diagram is on page 18 of the PDF file or page 12 in the manual. You will find the manual here: http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/P4M8OOPRO-MV2.0.zip or by clicking Here.
Hope this helps. If it does, please accept and rate the solution! You can leave a testimonial or contact me with any more questions you may have. Thanks for using FixYa!
EliteGroup ECS... | Answered on Dec 26, 2013
Hello the driver is available here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=530&DetailName=Feature&MenuID=24&LanID=0
Select download and vga and click on the link for download.
Here is only drivers for windows xp so if you run another system add a graphic card on the mainboard suppoting your windows.
Good luck
EliteGroup ECS... | Answered on Jan 04, 2013
Pleas sound cord is problum
EliteGroup ECS... | Answered on Mar 14, 2012
test all leads that attach to your hard drive including electrical extensions the leads from your ((motherboard to your hard drive)) IDE/SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you also clean your
computer all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
hope this helps
EliteGroup ECS... | Answered on Feb 15, 2012
Its a socket 478.
EliteGroup ECS... | Answered on Oct 27, 2011
Hi, there is no driver for windows 7:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=673&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
There is only drivers for windows xp.
You can try the driver
aslong its 32 bit system you are running.
Try to select the compatible mode when you install the driver.
EliteGroup ECS... | Answered on Sep 08, 2011
Hi, you can try to upgrade the driver from here:
Or you maybe have to look for a better graphic card.
Its a AGP 8X/4X card It has to be in the yellow slot on the mainboard.
Hope this was helpfull.
EliteGroup ECS... | Answered on Aug 19, 2011
You should not need to install or upgrade any drivers for a new hard drive. Windows XP and especially Windows 7 should automatically detect the hard drive and install it whether it is an internal or external drive.
EliteGroup ECS... | Answered on Mar 01, 2011
Click HERE to ECS P4M800-M Bios download page.
EliteGroup ECS... | Answered on Feb 15, 2011
you can use ATX version of this motherboard. 450W is prefer.
EliteGroup ECS... | Answered on Feb 04, 2011
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
EliteGroup ECS... | Answered on Jan 24, 2011
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
EliteGroup ECS... | Answered on Dec 30, 2010
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
Popular Tags
83 questions posted
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
video drivers problems
  • Computers & Internet
