20 Most Recent
Polaroid PDV-0813A Questions & Answers
The disc is clean; the power is fine. Just
there are two reasons for this problem:
1.) The problem could be from the mechanism. That is, the disc might not seat well to its appropriate place, thereby not allowing the lens to read the data on discs
2.) The problem might be from the lens. The lens might be very weak such that it cannot load or read data on discs.
You can open up the player, check the side of the lens, you will see a plus (+) sign, use a star screw driver to adjust the plus sign, either by increasing or decreasing, this will help the lens to load discs fast.
Electronics are not always reliable, it can develop fault at any point in time. It doesn't matter how careful you maybe, except any fault from electronics.
I wish you good luck.
5/20/2010 8:53:22 PM •
Polaroid...
Answered
on May 20, 2010
No Disk
When I try to play a DVD, operation seems normal, the unit makes a slight noise like the disk is rotating and "Loading" is displayed. Then after about 30 seconds the message "No Disk" is displayed. Then just the Polaroid screen is displayed. I have lost the remote control but surely the unit will play using the front panel buttons. One thing, only the remote is named as having a Setup Button in the manual but the unit has no such button.
11/7/2008 11:24:28 PM •
Polaroid...
Answered
on Nov 07, 2008
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
How do I switch my Polaroid P40LED13 TV on to AV mode. No option in sources
If you are using the standard SNES cables with the round red, white and yellow 'Jack' plug connectors they are referred to as "Component" connections. On your remote there should be a button marked "COMP". It will probably be near the top of the remote near the Power button. This should switch the TV to the channel you need.
3/27/2023 9:22:04 PM •
Polaroid...
Answered
on Mar 27, 2023
Polaroid pdx-0758 dvd player displays "open" even though thelid is properly closed, and it will not play
If your Polaroid PDX-0758 DVD player is displaying "open" even though the lid is properly closed, there are a few potential solutions you can try:
- Check for obstructions: Make sure that there are no objects blocking the DVD tray or preventing it from closing all the way. Even small objects like dust or debris can interfere with the DVD player's operation.
- Reset the DVD player: Try unplugging the DVD player from the power outlet and waiting a few minutes before plugging it back in. This can sometimes reset the player and clear any errors that might be causing the "open" message to appear.
- Clean the DVD player: Use a soft, dry cloth to clean the DVD player and remove any dust or debris that might be interfering with the player's operation.
- Try a different disc: Sometimes, a specific disc might cause the "open" message to appear. Try playing a different DVD to see if the player operates normally.
If none of these solutions work, there could be a more serious issue with the DVD player's hardware or firmware. In this case, you may need to contact Polaroid customer support or a certified repair technician for further assistance.
3/15/2023 8:15:20 PM •
Polaroid...
Answered
on Mar 15, 2023
My polaroid TV model 3200 has vertical lines in the picture and color is a little bit off. Any solutions?
The issue you're describing with vertical lines in the picture and a color imbalance on your Polaroid TV (model 3200) could be caused by a few different issues. Some possible solutions include:
- Check the TV's cable connections: Make sure all cables (e.g. HDMI, AV, power) are securely connected to the TV and the source device (e.g. cable box, DVD player).
- Adjust the TV's settings: Check the TV's picture settings (brightness, contrast, color) and make sure they are set correctly. You can also try resetting the TV to its default settings.
- Check for interference: Ensure that there are no other electronic devices or appliances that may be causing interference with the TV's picture. Move the TV or other devices a few feet away from one another to see if the problem persists.
- Check for a faulty cable or source device: Try connecting the TV to a different source device or cable to see if the problem persists. This can help determine whether the issue is with the TV or with the cable or source device.
- Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. This could be a problem with the TV's screen or the circuit board. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
Please note that the age of the TV, if it's been dropped or mishandled, or if it's been exposed to extreme temperature changes or moisture, could also be a factor in the problem.
1/26/2023 1:24:33 PM •
Polaroid...
Answered
on Jan 26, 2023
