20 Most Recent Polaroid izone 550W Digital Camera Questions & Answers
Use the right arrow button on the arrow pad. There is a little pic of a lighting bold beside a pic of a camera on the top left hand corner. Push the right arrow button and look at that lightning bolt you will see it changing. There are three different ones. One has a ling through it and that means no flash on had an "A" on it that stands for automatic and then you will see just a pic of the bolt without anything. Not to sure what means either. Hope this helps.
Polaroid izone... | Answered on Aug 13, 2011
izone 550W has 16MB own internal memory. In addition it takes SD-cards. I'd say since it's quite a new model it'll handle at least 8GB card which is more than adequate (over 2000 frames on highest resolution)
Polaroid izone... | Answered on Jun 19, 2010
Have you tried all your USB ports?
Polaroid izone... | Answered on Jun 12, 2010
Remove the card. Go into the camera menu and find "format"...follow the on-screen directions.
Polaroid izone... | Answered on Jan 13, 2010
Polaroid has a PDF of the user's guide on their site. I'll post a link
It's 84 pages long. Enjoy! http://www.polaroid.com/service/userguides/digital/cameras/izone300_ug_en.pdf
Polaroid izone... | Answered on Jul 01, 2009
I dont think its supposed to have sound...is it?
Polaroid izone... | Answered on Apr 21, 2009
If you hit the button with the green playback, it should show you all pictures on your camera, even the ones on the card.
Polaroid izone... | Answered on Mar 16, 2009
i think i got a fix!!! tyere is a small opening next to the white toggle button,between >> arrows and below the /set .be careful and push a small object like the end of a tiny paper clip etc... this will reset the camera!!this worked!
pop out the SD memory card. look for a tiny switch (lever) on the card and move it to the other position (the position that does not say "lock") and try again
Polaroid izone... | Answered on Jul 21, 2008
u need to put it in a bright area
Polaroid izone... | Answered on Jun 14, 2008
Check out the manual i posted. it gives ya step by step directions.
Polaroid izone... | Answered on Apr 06, 2008
I would suggest the format option in the menu. i posted the manual it gives step by step getting to the format option. if it works on one but not the other even after formatting in problematic camera. I would suggest getting a different brand/size. There's a 1gig liimit, but i am currently using a panasonic 2 gig and it seems to be working at its stated size. Although i haven't filled it to see if any problems occurr.
Hope this helps.
might have a fix!!! on the lower right hand side of the menu toggle button,between the >> aroows and beloww the set there is a small opening.be careful and push lightly a smaal object like the end end of a paperclip etc!!! into the hole.i did this ,the camera reset & works fine!
Polaroid izone... | Answered on Jan 09, 2008
You may want to check with Polaroid to see if there's a service advisory pertaining to faulty CCD chips that effect LCD operation. Most camera manufacturers got a bad batch of these chips and are repairing them at no cost.
Another option is to reset your camera and use recommended batteries.
J. DeRuvo
Digital-Camera HQ
Polaroid izone... | Answered on Dec 04, 2007
hmnn
do you have a memory card?
that may be the problem.
on my camera i can take 4 pics but i got a memory card and i can take like 400 pics.
hope this helps
Polaroid izone... | Answered on Nov 18, 2007
Polaroid izone 550W Digital Camera Logo
Popular Tags
27 questions posted
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
Polaroid Cameras
  • Polaroid Cameras
Most Popular Question
camera remains green light
  • Cameras
