Troubleshooting & Support for
273 people viewed this product
It seems that the resolution t hat you have set on your PC is not supported by the TV. Try starting the...
Does this happen while watching the tv through a cable service or satallite service or does this als...
If it does it strictly on a single side of the screen then the T-con board is faulty - the processor res...
i think you need hdmi input for that
You already check the fuse inside near the power supply?Check also the power supply if they have pow...
Hi A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and...
If this is a CRT TV, then you have a deflection problem. In that case is advisable to contact a tec...
Hi, A lot of things could go wrong. Initially, a couple of ideas: could be on video/audio mute due...
If blue light blinks continiously, the falult must be to its main digital board. Check this link if you...
Check whether the menu button on it front panel controls are struck or not.
I would guess bad shielding/ ground, of transformer going bad.
Maybe worth a shot, carefully thouRemove 2 * screws under battery coverfront of remote: slide down the...
You have to disassemble it screen. It is a skilled work. Will be better to contact any service tec...
Cross-talk with polorizer and glass inside panel might be the cause. If you wish to get more det...
Have a tip for Tatung V20CCBX-U02 Television?
I have a lg 32lk330 tv. Today there was a storm and before the storm everything was working fine but...
i would like someone to tell me how to get google set up on my tv
Panasonic Vierra E3 series. Went to turn on one day and tv cycled on and off three times, before...
