20 Most Recent
Zenith XBV613 DVD/VCR Combo Questions & Answers
Progressive scan
Always state your MAKE and MODEL when asking for help with regards to any product or item.
We have a DVD/VCR Combo the number on it is
Here you can find the user manual
http://www.manualowl.com/m/Zenith/XBR716/Manual/56434
At page 18 you will find how to reset the Lock Settings : press Home, select Setup, Start and press Enter, input 210499 and press Enter - it will be unlocked.
If that fails you will have to reset the entire unit, explained at page 46: press Power button for more than 5 seconds - the unit will shut down; again press Power shortly to tun it on; unplug it from the mains, wait a minute and plug it back; start it and it will be reseted.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
