20 Most Recent Star Micronics TSP100 Thermal Printer Questions & Answers
use its utility to configure ip address
Star Micronics... | Answered on Nov 30, 2017
http://www.starmicronics.com/absolutefm/absolutefm/afmviewfaq.aspx?topicid=27&faqid=235
Star Micronics... | Answered on Jun 02, 2016
If you have a TSP100, it should have a power switch, located on the left side of the printer, halfway back along the base. Here is a link to the manual which shows a picture of the switch location.
Star Micronics TSP100 Hardware Manual Turning Power On
Star Micronics... | Answered on Nov 07, 2015
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Star Micronics... | Answered on Dec 22, 2014
Is this the networked Star TSP or the USB version? If it's networked you may want to make sure that you're still connected to the network by printing out a test receipt (power the printer off, hold the feed button down while it's off and continue holding the feed button after turning the printer back on until it prints a test receipt - the second receipt will give IP configuration information).
If you're not receiving a valid IP address you may be having network issues - you might consider assigning the printer (you might need to power cycle your router and printer to get initially connected again in order to do this).
You can also try resetting the printer to its default configuration - you can find instructions here:
Star TSP100Lan Network Troubleshooting Unable to Detect the Printer within...
Star Micronics... | Answered on Dec 12, 2014
the Auto-cutter on that model is only a 'partial' cut, (Guillotine-style.)
Since it is an Auto-cutter, if it is not cutting AT ALL, that is not something that a "user" can adjust-for.
See section 7-3 Releasing a Locked Cutter (pg 26) in your manual here:
http://get.acclivitysoftware.com/copdfs/TSP100PrinterManual.pdf
Star Micronics... | Answered on Nov 07, 2014
You'll need 3-1/8 x 230 thermal rolls for this printer. I've see it at a number of places. Staples, BJ's, Restaurant Depot, Restaurant store etc etc.
Star Micronics... | Answered on Jun 21, 2014
u have to increase darkness
and decrease speed too.
Star Micronics... | Answered on Jun 29, 2013
from printer properties --> preferences --> device options -->
1- speed setting ( set it to low speed to have clear print) and
2- Head setting ( set darkness to upper digit to have clear print)
Star Micronics... | Answered on Jun 26, 2013
Star Micronics TSP100 Thermal Printer Logo
111 questions posted
Top Star Micronics Office Equipment & Supplies Experts
polytek
Norman Al-Anbar
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Star Micronics Office Equipment & Supplies
Most Popular Question
ink run out
  • Office Equipment & Supplies
