SuperMicro H8DAE Motherboard
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with SuperMicro H8DAE Motherboard?
Troubleshooting and Support
Solved Problems for SuperMicro H8DAE Motherboard RSS Feed Post a New Problem
H8DAE-0 Fan issues, stopping and starting.
I have an H8DAE-0 board installed in my system and the fans will come on for a few seconds and then stop. I checked the...
1 Solution
new Areca driver in 2.6.16-rc6-mm2 appears...
Dear Chris Caputo, Could you tell me about the file system of testing volume on bonnie++ ? Does this issue come...
13 Solutions
shuttle pc motherboards
Hi I am trying to upgrade my shuttle pc, but I am finding it hard to get components that fit into a shuttel pc. E.G....
1 Solution
format a corrupt system without 98...
Is it possible to format a c:of win98 in a corrupt system without bootable?if yes then how?
1 Solution
Removing hard drive
How do I remove and replace a hard drive on my laptop.
1 Solution
check engine light 2001 ford taurus
the first reading i got was mass airflow sensor bad replaced with new one problem hasnt been removed code reads not...
1 Solution
sobre micro y placa madre
deseo saber ademas de el soket 7 si le sirvbe a la aptiba de ibam potro tipo de micro conotro soket o se le puede adptar...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Form FactorExtended ATX
CompatibilityPC
ChipsetAMD-8111 / AMD-8131
Compatible ProcessorsAMD Opteron
Front Side Bus Speed1000 MHz
Technical Features
Expansion SlotsPCI x 2 · PCI-X 64 Bit (66/33 MHz) x 2 · PCI-X 64 Bit (133/100/66 MHz) x 2
Integrated Input/Output PortsSerial Port x 2 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · USB 1.1 x 5 · Floppy Port x 1 · RJ45 Lan Port x 2
Storage Controller Type(s)DMA/ATA-133 (Ultra) x 2
Processor
Max supported CPUs qty2
Socket TypeSocket 940
Memory
Max Supported RAM32 GB
Memory TypeDDR SDRAM
Supported RAM Speeds400 MHz · 266 MHz · 333 MHz
Number of Memory Slots8 x 184 Pin DIMMs
Audio / Video
Installed Video Memory8 MB
Integrated Graphic CardIntegrated Graphic Card
Video Out Ports15 Pin D-Sub VGA port x 1
On Board Graphic ProcessorATI Rage XL
Communication
Networking TypeDual Network adapters, Ethernet, Gigabit Ethernet, Network adapter, Fast Ethernet
Other Features
Package Qty1
Chassis TypeServer
Other FeaturesDual Channel Memory Architecture · Chassis intrusion detection
FansFan Speed Control
Dimensions
Depth12 in.
Width13.05 in.
SuperMicro Contact Information
Main support number1-408-503-8000
Support FAX1-408-503-8008
Email supportSupport@Supermicro.com
Sponsored Links
Loading problems.
Top Motherboard Experts
sandrew
13 solutions
Operating Systems, PC Desktops, PC Laptops...
Ask Me
Wiz
acdr
3 solutions
Software, Computer Hardware, Computer Components...
Ask Me
Wiz
Wraithbe
1 solutions
Ask Me
Master
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
