20 Most Recent
Tally MT661 Printer Questions & Answers
When printing go to offline automatically
Dear Mr. AshraffThanks for posting. The problem is with the online button and needs to be attended. Try to check and make sure the button is working fine and not dumped pressed as this is the only common Button used often. If faulty then needs to be replaced.Regards,Saleem
Error message bad esc seq
The Bad Esc error you are seeing indicates the pritner is reciving data from the host computer system that it does not recognise, the most likely cause for this error are;
- You are not using the correct pritner driver to print to the pritner
- The Emulation setting on the pritner is not correct, you can check this via the printers menu - I would guess the pritner has defaulted to MT660 emulation and it needs to be set to Epson or IBM emulation
Tally mt661 printer gives data overrun error after
The Data Overrun error is normaly associated with the incorrect serial interface settings on the pritner or the serial cable may have the wrong pin configuration or be damaged in someway.
I would recomend checking the serail interface settings including the follwoing settings; Parity, Protocol, start bits and stop bits
What is tally ?
Tally is an accounts and inventory management software which is having many other features too. With the latest version of this software Tally9 you can
1. do all basic accounting functions,
2. Manage your store and items,
3. do the job costing,
4. manage payroll,
5. get many mis reports which are useful for day today functions,
6. file your tax returns like prepare balance sheet, profit and loss statement, VAT forms, TDS, returns, Service tax returns, e-TDS filing, Excise forms, FBT reports and forms,
7. maintain budgets, scenarios,
8. calculate interest on pending amount
9. manage data over different locations and synchronize it and many more other features.
In fact in todays environment you just need a computer and Tally to manage your business and you to run it.
you can get more info on tally at
http://apnitally.blogspot.com
Hope this can help you to understand tally better.
Does not sense paper
The paper-out sensor can be calibrated. Press and and hold the keys LF+ENTER > 3 sec. until "Tech.Access ON" appears on the display. Then press MODE -> 1-TEST -> 2-DIAG -> 3-PrntCal -> PapOut -> ENTER. Then follow the instructions shown on the display (important: close the tractor doors whilst calibrating the paper-out condition.
