20 Most Recent
RupseTM For VW: New BORA / PASSAT CC / PASSAT B6 / JETTA A5 / GOLF PLUS / GOLF 5 / Golf GTI / Golf R32 / Scirocco / Tiguan / Touran / Caddy / EOS / Rabbit / SKODA: Octavia Limousine / Octavia Combi / Fabia Limousine / Fabia / Roomster/ Praktick / SEA Questions & Answers
My dash all works properly for two to three seconds then everything shuts off. All other things work fine. Any ideas?
YOU MAY HAVE A INTER MITTEN SHORT, A BULB MAYBE GETTING READY TO BURN OUT, THE VIBRATION WHEN YOU START THE CAR IS SHORTING OUT. 2 THINK TO CHECK THAT ALL THE GROUNDS ARE CLEAN AND THERE IS NO CORROSION, ON INSIDE THE INSTRUMENT PANEL, OR THERE IS A GROUND WIRE SOME WHERE IN THE ELECTRICAL SYSTEM THAT IS LOSING IT CONNECTION, A SCREW THAT HOLDS THE CONNECTION TO THE GROUND IS LOOSEN UP. YOU MITE HAVE TO TAKE IT TO A DEALER OR A PERSON THAT WORKS ON INSTRUMENT PANEL OR LIVE WITH IT UNTIL IT FINAL SHORTS OUT OR STOPS WORKING.
***************************************IMPORTANT***************
it is easier to repair as it is now that later because they have a way of sending a signal on a wire and by figuring out the time of the signal and distance they have a place or ruff idea where the short is, if it stops working all together you are talking a lot more money to troubleshoot the problem and cost searching for a needle in a hey stack, and miles of wire harness in your car. if it now not later!!!!
Hello , I have a new Tiguan trend and fun 2.0 and my dash light and radio won't work.
Check the manual and find the fuse box or boxes. find the dash lite
fuse, it may say " interior illumination" If it is good check also the radio fuse.If the fuses are good, you have to visit a wv dealer for detailed fault finding.If the car still have warranty, don`t mess with the electrical system.The car also have can bus electrical system, and it can go wrong when you try to fault find your self.The fault could be the light switch, fuses, the radio.Here is a fuse list for a golf:
http://mit.edu/dennis/www/vw/fuses.htmlCheck the Fog light relay, instrument panel light dimmer switch fuse.Good luck
What does the code 00518 mean on a vw bora 2.0
Hello the fault means:Throttle Position Sensor - Signal Out of Range (G69) Also check for loose ECM power relay.The fault can be solved by cleaning the throttle valve and reseting the sensor after the valve is been cleaned for dirt.The fault comes when the valve does not close properly.This is not a home job.The wv dealer can clean and reset the sensor for you.Here is more fault codes in pdf format:
http://www.airbagnews.com/PDF/Fehlercodes%20VAG%20english.pdfYou need adobe reader to read the content.Good luck
What Questions to Ask When Looking at Preschools?
For parents seeking reliable and nurturing
daycare in Kannivakkam, Chocolate Kids Daycare is an outstanding choice. With a focus on providing a safe and supportive environment for children to grow and learn, Chocolate Kids Daycare offers a range of enriching activities tailored to meet the developmental needs of each child. The experienced and caring staff ensure that children receive personalized attention and guidance, fostering their social, emotional, and cognitive development. Additionally, the daycare facilities are equipped with engaging play areas and nutritious meal options, ensuring that children are happy, healthy, and engaged throughout the day. As a parent, I wholeheartedly recommend Chocolate Kids Daycare to families in Kannivakkam seeking high-quality childcare services.
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
