during processing, the lens' moving suddenly became out of control with its incapability of...
(More)
during processing, the lens' moving suddenly became out of control with its incapability of shrinking back to its static location original, and doesn't work any more. how do i fix it?
there is a flashing icon in the upper right area of the screen (can't quite make out what it is) and...
(More)
there is a flashing icon in the upper right area of the screen (can't quite make out what it is) and the camera is making a sort of chirping noise when turned on -- it seems to still take the photos ok, but....? would be grateful for advice!
I am trying to install my Nikon software on to my laptop and after it installs the ArcSoft, and the...
(More)
I am trying to install my Nikon software on to my laptop and after it installs the ArcSoft, and the screen says "Nikon installation", it reads corrupt file, catastropic failure. I don't know what to do next. I installed this software on my home computer when I first got the camera 4 years ago and now I am trying to install it on my laptop. The CD has been in a CD case away from the elements. HELP
the battery access door will not close because the plastic hold tab has broke off... can this door...
(More)
the battery access door will not close because the plastic hold tab has broke off... can this door be replaced and if so what would be the approximate cost?
These are some of the problems I have encountered over the years. It mainly relates to Fuji digital compacts but could just as easily relate to any...
written by daveward712
This tip is for Kodak V803 cameras that will take pictures fine but you can only be able to see them if you download them onto a PC. A replacement...
written by sharcnet
#1: Remove the batteries from the camera, wait a few
minutes. Put a fresh set of batteries back in and turn the camera on. #2: Remove the batteries,...
written by dileep007
I had this problem for a while and after sending it into the shop I was told that it was because of a small piece of sand that had been lodged between...
written by jessemphotos
When the lens will not retract and camera is not functional (no picture on
display, and does not shoot) , and you already tried replacing
batteries...
written by ginko
Surprisingly enough, most freezing problems (and other problems, too) can be solved by gently hitting your camera. It works! Just remember to be...
written by Noaya
This article describes how to modify an ordinary webcam to capture images in the near infrared wavelength. All that is needed are two very small...
by wikihow
Worldwide AFFORDABLE digital camera repair & par... Read More
Worldwide AFFORDABLE digital camera repair & parts.
We can repair most broken lenses for only about $85! We also have amazing prices for LCD repair, OR you can buy the part and install it yourself for even less!
Check out our site for more information!
CamerasAndParts.Com Specializes in the Service / Rep... Read More
CamerasAndParts.Com Specializes in the Service / Repair of Canon PowerShot Digital Cameras / Canon Digital Camcorders! We also offer a Huge Selection of both New / Used Genuine Canon Parts! Let us do it for you, Our Complete Service / Repair Packages are available for all Canon Powershot Cameras and the value is simply unbeatable! Let us help :)
Specifications for Nikon Coolpix 4300 Digital Camera
Key Features
Camera Type
Standard Point and Shoot
Image Sensor Type
CCD
Resolution
4.1 Megapixel
Optical Zoom
3x
Lens
Focus Type
Autofocus & Manual Focus
Focal Length
8 - 24 mm
Interchangeable Lens
Without Interchangeable Lens
35mm Zoom Lens
38 - 114 mm
Digital Zoom
4x
Macro Focus Range
1.6 in. to Infinity (w) / 12 in. to Infinity (t)
Focus Range
12 in. to Infinity (w) / 24 in. to Infinity (t)
Image Quality
Camera Resolution
4.1 Megapixel
Image Resolutions
1600 x 1200 · 640 x 480 · 1024 x 768 · 2048 x 1536 · 160 x 120 · 320 x 240 · 1280 x 960 · 2272 x 1704
Video
Video Resolutions
320 x 240 (QVGA)
Video Speed
15 fps
Max Movie Length
40 Seconds
Video Format
QuickTime
Exposure Control
Shutter Speed
8 - 1/1000 sec
ISO Speeds
200 · 100 · 400 · Auto
Aperture Range
f2.8/f4.9 (w/t)
White Balance
Manual · Auto
Storage
Memory Type
CompactFlash Card Type I
Compression Modes
Fine · Normal · Uncompressed · Basic
Compression Type
JPEG
File Size (High Res.)
16 MB (8 images on 128MB card)
File Size (Low Res.)
.07 MB (about 1,829 images on 128MB card)
Flash
Flash Type
Built-in
Flash Functions
Flash Off · Auto Flash · Fill-in Flash · Red-eye Reduction Flash · Slow Sync
Viewfinder / Display
Viewfinder
Optical (Through-the-lens)
LCD Panel
With LCD Panel
LCD Panel Size
1.5 in.
LCD Screen Resolution
110,000 pixels
LCD Protected Position
Without LCD Protected Position
Interfaces
Video Interface
Video Out
Interface Type
USB
Included Features
Self Timer
10 Sec. · 3 Sec.
Mp3 Built In
With Tripod Mount
System Requirements
Operating System
Microsoft Windows XP Home Edition · Microsoft Windows XP Professional · Microsoft Windows 98SE · Apple Mac OS 9 · Apple Mac OS X · Microsoft Windows 2000 · Microsoft Windows ME
Dimensions
Depth
2 in.
Height
2.7 in.
Width
3.7 in.
Weight
0.49 lb.
Nikon Contact Information
Main support number1-800-NIKON-UX , 1-800-NIKON-US
