Frigidaire FAH146Q2 Thru-Wall/Window Air Conditioner
Problems with Frigidaire FAH146Q2 Thru-Wall/Window Air...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Frigidaire FAH146Q2 Thru-Wall/Window Air Conditioner RSS Feed
View More Results for Frigidaire FAH146Q2 Thru-Wall/Window Air Conditioner
Find a Manual
Frigidaire FAH146Q2 Thru-Wall/Window Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central... written by heatman101
Air Conditioner Trouble -Review the Possibilities
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check... written by heatman101
Air Conditioning - Cleaning the Condenser Coil
Air Conditioning works by exchanging heat from inside a building to the outside air. To do this some very basic refrigeration principles... written by heatman101
testesttest
test test tes test written by bstreet
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for FAH146Q2 Thru-Wall/Window Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Rate and Review the Frigidaire FAH146Q2 Thru-Wall/Window Air Conditioner
Write a review:
Rate this product:
Would you recommend the FAH146Q2 Thru-Wall/Window Air Conditioner to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Frigidaire FAH146Q2 Thru-Wall/Window Air Conditioner
Other Features
ENERGY STAR
Without ENERGY STAR??
Swing Louvers
Up / Down · Left / Right
Key Features
Type
Thru-Wall/Window
Remote Control
With Remote Control
Cooling Capacity
14000 BTU/hr
Energy Efficiency Rating
9 EER
Fan Speeds (Cooling)
Electrical Requirements
Voltage
230
Dimensions
Depth
22 in.
Height
14.5 in.
Width
24 in.
Frigidaire Contact Information
Main support number1 (800) 374-4432
Describe your problem:
Top Air... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
