Frigidaire FAA084P7 Thru-Wall/Window Air Conditioner
Problems with Frigidaire FAA084P7 Thru-Wall/Window Air...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Frigidaire FAA084P7 Thru-Wall/Window Air Conditioner RSS Feed
View More Results for Frigidaire FAA084P7 Thru-Wall/Window Air Conditioner
Find a Manual
Frigidaire FAA084P7 Thru-Wall/Window Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
Tips & How To Guides for the Frigidaire FAA084P7 Thru-Wall/Window Air...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Air Conditioner SEER Seasonal Energy Efficiency Ratio
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA. Energy Policy Act mandates minimum... written by heatman101
R-410A The New Refrigerant for Air Conditioning
R-410A possesses excellent cooling capacity and operates at 50% higher pressure. R-410A is a mixture (blend) of refrigerants that create properties... written by heatman101
What Size Air Conditioner Do You Need?
Air conditioning is not an exact science. There are many variables that can affect the way an air conditioning system performs. Also there are many... written by heatman101
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's... written by heatman101
Window Air Conditioners - Clean them every year
The Window Air Conditioner that you bought last year is not performing like it did when it was new. What can you do to get the slightly cool to cold... written by heatman101
Does your A/C coil freeze up?
This is actually something that causes more service calls than actual failures. Those who do not have the knowledge to fix it has to make that dreaded... written by cj2176
You can add Air Conditioning to Your Hot Air Furnace
Air Conditioning is easier to add to an existing central hot air heating system then you might think. Both systems use air to move the heating or... written by heatman101
Old motor has 3 wires, new motor has 4 wires, WTF?
You always want to save a few bucks in these tough times right? Don't want to spend a fortune replacing the motor with the exactamundo. So you... written by TheMobilian
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Frigidaire FAA084P7 Thru-Wall/Window Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Ratings for the
Find a Warranty
Specifications for Frigidaire FAA084P7 Thru-Wall/Window Air Conditioner
Other Features
Moisture Removal (Pt/h)
2.1
Filter
Reusable
ENERGY STAR
Without ENERGY STAR??
Swing Louvers
Up / Down · Left / Right
Cooling Operating Range
60 - 90
Key Features
Type
Thru-Wall/Window
Remote Control
WithRemote Control
Cooling Capacity
8000 BTU/hr
Energy Efficiency Rating
9.8 EER
Electrical Requirements
Voltage
115
Cooling Ampacity
7.4
Cooling Watts
815
Dimensions
Depth
15.5 in.
Height
12.5 in.
Width
18.5 in.
Warranty
Warranty
1 Year
Frigidaire Contact Information
Main support number1 (800) 374-4432
Describe your problem:
Top Air Conditioner Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
