20 Most Recent NexxTech new 3.5-inch hard drive enclosure nexxtech Questions & Answers
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
NexxTech new... | Answered on Nov 22, 2012
Don't go with Time Warner. That will be your first mistake.
NexxTech... | Answered on Feb 04, 2019
Contact Nexxtech on the web. Look for Support/Downloads/Manuals.
NexxTech... | Answered on Jan 04, 2019
No question - how can I help if you don't ask a question???
Contact Nexxtech on the web. Look for Support/Downloads/Drivers.
THeir website. - nexxtech is where I would go. Check for their support page.
Look it up on their support website.
Check the support site for the product and select downloads.
You likely won't need one. What should happen is the windows bluetooth driver should auto install. I have had like 4 of these things. If the bluetooth drive fails to install you may have a bad adapter.
NexxTech... | Answered on Dec 29, 2018
Disk drives usually won't take a mini disk. As an alternative location for the drivers for the adapter, check the Nexxtech website. I can't link specifics as I don't know what model you have.
NexxTech... | Answered on Aug 02, 2018
Unsure if this is the same manual you are looking for:
https://www.thesource.ca/download/EN/2738413_Manual.pdf
Please use Comment menu to add information to your question.
NexxTech... | Answered on Jul 01, 2018
Hello, Trese -
I have only found a Nexxtech GPS cushion with the model number 1907011, which apparently is no longer made.
See:
https://www.thesource.ca/en-ca/gps,-car-and-marine/gps/car-gps/nexxtech-gps-cushion/p/1907011
Best wishes.
NexxTech... | Answered on Feb 11, 2018
Solvusoft Microsoft Gold Certified Company Download the Nexxtech Driver Utility from the link. This will allow you to install the proper driver for that model.
NexxTech... | Answered on Nov 29, 2017
NexxTech new 3.5-inch hard drive enclosure nexxtech Logo
2 questions posted
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NexxTech Computers & Internet
Most Popular Question
nexxtech new 3 5 inch hard drive
  • Computers & Internet
