20 Most Recent Whirlpool 30 in.GJC3054 Electric Cooktop Questions & Answers
My whirlpool gold cooktop has the control lock button lit up- i can't turn on any buners?
Hello there and welcome to fixya This is a fairly common issue with these These cooktops have a internal memory built into them and if they get locked they need to be reset SO what you will need to do is to unplug the power to the cooktop and leave it sit for 1 hr and do not touch ok then after the hour is up tunr on the power to the cooktop you may hear a audiable beep sound or a click sound this is normal now press the cancel button and you should be all right from here but if not please post me back a comment and tell me what is going on and i will give you further troubleshooting steps ok ?Best regards Mike
12/31/2011 7:41:41 PM • Whirlpool 30... • Answered on Dec 31, 2011
2answers
How to lift open a whirlpool gas oven cooktop, have a knob that is loose from inside?
Here is a disassembly video. A loose knob problem can be tackled by pulling off the knob, encircling the cracked plastic with a zip tie (after putting Loctite glue in the cracks), pulling the zip tight. Don't lose the sleeve when you pull off the knob. But if this is not working for your setup, here is the disassembly, not your model but maybe useful: https://www.google.com/search?q=whirlpool+gas+top+disassembly
1/4/2022 6:10:40 PM • Whirlpool... • Answered on Jan 04, 2022
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
8/3/2017 3:19:40 AM • Whirlpool... • Answered on Aug 03, 2017
All burners keep blinking and can't turn off
unplug it and replace the main board or get a new stove
5/8/2015 10:28:26 PM • Whirlpool... • Answered on May 08, 2015
One of the large plate not working
What is the model number?
6/17/2014 4:54:26 PM • Whirlpool... • Answered on Jun 17, 2014
The burners pop whenever the gas is on
You didn't mention if it only pops when you first turn them on or that the popping is continuous. If it when you first turn them on, then I would suspect late ignition. Too much gas build-up before ignition takes place. The spark gap may need to be adjusted or the spark module replaced. If it happens continuously there may be a short in one of the switches or wiring harness.
6/1/2014 7:06:30 PM • Whirlpool... • Answered on Jun 01, 2014
Whirlpool wfe361lvq electric range
and the problem is? please post afresh with full details
5/13/2014 10:29:33 PM • Whirlpool... • Answered on May 13, 2014
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
5/10/2014 11:47:16 PM • Whirlpool... • Answered on May 10, 2014
Whirlpool 30 in.GJC3054 Electric Cooktop Logo
1 questions posted
Top Whirlpool Cooktops Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Cooktops
  • Whirlpool Cooktops
Most Popular Question
whirlpool gold cooktop control lock
  • Cooktops
