20 Most Recent Whirlpool Refrigeration Stainless Side Trim Perimeter Kit, Fits KSBP25KSS, KSCS25FKSS, GD25FFCH, GD2... Questions & Answers
My freezer has a hot pipe in the freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/12/2011 2:29:59 AM • Whirlpool... • Answered on Aug 12, 2011
Disconnecting water line for water dispenser, do
May need your model number to confirm. But older styles have the compression nut with farrow on the water line to prevent leakage.and newer types have snap lock fittings. If yours is one of the models listed above the question would be what part of the dispenser system are you attempting to remove and replace? If you model is the=> KSCS25FKSS00 then click on photo again to enlarge. All fittlings appear to have the compression nut. The water Control Valve=> 2199838 Water Inlet Valve
Here is a link to the KSCS25FKSS Parts Manual
You may also get Whirlpool User Manuals and part manuals HERE
I may not have answered exactly the answer you want but I belive you twist them with a wrench at this time.Hope this helps, Thanks Sea Breeze
5/4/2011 5:05:45 PM • Whirlpool... • Answered on May 04, 2011
Whirlpool wrv986fdem01 no lights
Check the control panel or display on the refrigerator for any error codes or indicators that might suggest a malfunction. Reset the control panel by unplugging the refrigerator for a few minutes and then plugging it back in.
4/3/2024 9:01:44 PM • Whirlpool... • Answered on Apr 03, 2024
Whirlpool refrigerator model WRB322DMBM0 1 with ice maker only. How do I find and change the ice maker filter
The Whirlpool WRB322DMBM01 refrigerator model typically does not have a dedicated water filter for the ice maker. Instead, it relies on an external water filtration system or an in-line water filter that may be installed in the water supply line connected to the refrigerator. Here's how you can check for and change the water filter for your ice maker: 1. **Locate the Water Supply Line**: Trace the water supply line that connects to the back of your refrigerator. The water supply line is usually a flexible plastic or metal tube that runs from the water source (such as a water pipe or faucet) to the refrigerator. 2. **Check for an In-Line Water Filter**: Look along the length of the water supply line for any inline water filters. These filters may be attached to the water line using compression fittings or push-to-connect fittings. They are typically cylindrical or rectangular in shape. 3. **Inspect the Filter**: If you find an in-line water filter, inspect it to determine its type and condition. Some filters have a label indicating the brand and model number, while others may have a date or indicator showing when it was last replaced. 4. **Replace the Filter (if Necessary)**: If the water filter is due for replacement or is visibly dirty or clogged, follow the manufacturer's instructions for replacing it. This typically involves turning off the water supply, disconnecting the filter from the water line, and installing a new filter in its place. 5. **Flush the System**: After installing the new filter, flush the water system to remove any air or debris. Run water through the dispenser or activate the ice maker to purge the system of any trapped air or loose particles. 6. **Monitor Performance**: Monitor the performance of your ice maker and water dispenser to ensure that the new filter is functioning correctly. It may take a few cycles for the water system to fully adjust to the new filter. If you cannot find an in-line water filter connected to your refrigerator's water supply line, it's possible that your refrigerator does not have a built-in water filtration system for the ice maker. In this case, you may need to consider installing an external water filtration system to improve the quality of your ice and water.
4/3/2024 12:33:05 AM • Whirlpool... • Answered on Apr 03, 2024
How to replace freezer light
Delete To replace the LED light in your Whirlpool WRSSDHW08 freezer, follow these steps:
  1. Unplug the refrigerator to ensure safety.
  2. Remove all the items from the freezer to give yourself more room to work.
  3. Locate the light cover inside the freezer. The LED light should be underneath this cover.
  4. Carefully pry the light cover off using a flat-head screwdriver or your fingers. Be gentle to avoid damaging the cover.
  5. Once the light cover is removed, you should see the LED light module. It may be held in place by clips or plugs.
  6. Disconnect the power supply to the LED light. This may involve twisting or pulling the plug from its socket.
  7. Remove the old LED light module from the freezer.
  8. Purchase a replacement LED light module from the Whirlpool website or an appliance parts store. Make sure to get the correct part number for your specific refrigerator model.
  9. Install the new LED light module by connecting it to the power supply and placing it back into its slot in the freezer.
  10. Replace the light cover by snapping it back into place.
  11. Plug the refrigerator back in and test the new LED light.
If you have any trouble replacing the LED light or if you are unsure about any steps, consult the user manual for your Whirlpool refrigerator or contact a professional appliance repair technician for assistance.
3/29/2024 9:30:21 PM • Whirlpool... • Answered on Mar 29, 2024
Why is my whirlpool refrigerator ice maker not working on whirlpool model # WRF535SMBM00. It seems we have no water filter
https://www.appliancepartspros.com/repair-help/whirlpool-refrigerator-wrf535smbm00-repair/wrf535smbm00-ice-maker-not-making-ice.html Whirlpool Refrigerator WRF535SMBM00 Ice maker not making ice Causes of a bad icemaker cycling thermostat can include electrical malfunctions, temperature sensor issues, or wear and tear. Symptoms of a bad icemaker cycling thermostat may include: Inconsistent ice production. The icemaker not cycling properly.
HOW-TO: Whirlpool Refrigerator WRF535SMBM00 Ice maker ...
There is no water filter.
Where is the filter for water for ice maker located on
JustAnswer https://www.justanswer.com > Appliance Repair Jul 23, 2018 - This particular model does not have a filter built into it so that is why you can't find one. If you wanted to add a filter, you can get an in- ...
2/23/2024 6:13:04 AM • Whirlpool... • Answered on Feb 23, 2024
2answers
Whirlpool refrigerator running continuously won't shut off but is not freezing stuff in fridge and freezer is working fine
Sounds like the evaporator fan is not running. Pull the inside of the freezer back off to expose the motor and replace it.
2/21/2024 6:59:51 PM • Whirlpool... • Answered on Feb 21, 2024
Whirlpool freezer defrosting too often causing food to thaw.
If it has a defrost timer, some are adjustable. If not just replace it. https://www.google.com/search?q=Whirlpool+freezer+defrosting+too+often ..
1/7/2024 7:49:35 PM • Whirlpool... • Answered on Jan 07, 2024
Whirlpool ET1MTKXKQ20. Temperature control.
Question edited for clarity, spelling of maker, toss in a load of CAPS. Question moved from Cars and Trucks. Yes they do. https://www.google.com/search?q=whirlpool+et1mtkxkq20 ..
1/1/2024 3:13:20 AM • Whirlpool... • Answered on Jan 01, 2024
Ice maker issues... Maytag Whirlpool French Door Icemaker in upper left. Help?
Question edited for clarity Zeros (0) and ohs (o) aren't interchangeable in serial numbers :>D If icemakers are going wrong it is best just to replace the complete icemaker unit. They work in a very hostile environment or cold, wet, electricity and limescale and bio-slime. Some commercial icemakers I have witnessed in catering facilities would have you never taking ice in a bar or restaurant again! https://www.google.com/search?q=Whirlpool+MFI26665XEW3+parts ..
10/17/2023 6:22:18 PM • Whirlpool... • Answered on Oct 17, 2023
6answers
I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions? [email protected]
10/7/2023 6:12:17 AM • Whirlpool... • Answered on Oct 07, 2023
Whirlpool refrigerator is not getting cold but freezer is freezing. Can someone help, please?
As the freezer is working you can probably discount that the reason is low refrigerant gas. The other reasons would be that the fridge circulation fan has failed. or The channel that directs cold air from the freezer is blocked with ice at the rear of the freezer. It happened to my GE and was caused by a failed defrost timer that was icing up the evaporator coils at the back of the freezer. A service call lasts about an hour including melting the ice with a heat gun..
10/3/2023 2:45:18 AM • Whirlpool... • Answered on Oct 03, 2023
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine b
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
9/29/2023 7:42:49 PM • Whirlpool... • Answered on Sep 29, 2023
My Whirlpool six sense American fridge freezer Digital display showing faults
A clue to what the faults were may help you get an answer.
9/29/2023 7:35:42 PM • Whirlpool... • Answered on Sep 29, 2023
How can I remove the top drawer from the bottom freezer of a Whirlpool fridge as the bottom drawer will not fully close?
Remove the ice build up at the back of the drawer or something may have fallen over the top edge.. To remove the drawer, lift at the front and pull, or look on the side rail for catches. Please always include full 'make model (what it is)', then we can refer to the owner or service manual.
9/29/2023 7:30:41 PM • Whirlpool... • Answered on Sep 29, 2023
Refrigerators Logo
5 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
freezer hot pipe in freezer
  • Refrigerators
