20 Most Recent
Desa International RFP30TA 30.000 LP Gas Heater Questions & Answers
We can not get the
Press and hold the knob to initiate pilot lighting process. Once the pilot is lit continue to hold the knob down for about 30-45 seconds in order for the thermistor to send the low voltage signal to the main gas valve. after the 30-45 second period, release the knob and turn to the on position.
11/27/2010 3:10:38 AM •
Desa...
Answered
on Nov 27, 2010
Haven't run heater for 6mons. Hooked up new tank
HI pilot line open letting full gas through , make up soap and water to make bubbles and brush it around all the joints get someone to turn on tank slowly and you and chek for leaks if it bubbles up if in any not sure get a gas fitter too check it out
2/21/2010 12:46:09 AM •
Desa...
Answered
on Feb 21, 2010
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
2/19/2018 12:59:43 PM •
Desa...
Answered
on Feb 19, 2018
I HAVE A DESA MODEL T36 NRA
I have same model, went to all parts.com and ordered pilot assembly for 105$ , has all in one kit.
Part # 108084-02 easy instal
Good luck
9/24/2013 8:56:59 PM •
Desa...
Answered
on Sep 24, 2013
Comfortglow modle cgn30tb @cgn30tlb,,,,light it and it burns good for 5 or 10 min,,,starts hissing and then poof it goes out..has been working fine up till now,,,,
Why gas log fireplace releasing black soot
Logs are likely not placed properly on the burner. Option two is if they are a vented gas log soot is normal, but only on vented sets. Unvented Logs will be soot free. Soot is a sure sign of Carbon Monoxide. Install a detector if you do not have one.
2/10/2013 11:44:21 AM •
Desa...
Answered
on Feb 10, 2013
