20 Most Recent Whirlpool GT4175S Microwave Oven Questions & Answers
The turntable motor probably needs to be replaced.
Whirlpool... | Answered on Jan 15, 2018
in most cases this is due to a snapped of push bar as they are made of plastic its a common fault. if the push bar is not snapped then its lost a plug that holds it in. as the microwave holds a constant 1000 watts of power i always recommend to people to have them fixed by lic techs the repair cost for this fault is around $ 100 if the part is still available
hop this helps please rank advice below
Whirlpool... | Answered on Dec 28, 2010
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Whirlpool... | Answered on Aug 28, 2010
The magnetron has failed and has damaged the waveguide. This type of failure is generally unrepairable. First look in your owners manual for specific warranties, then contact Whirlpool and explain to them what has happened.
If you need further assistance, let me know
Regards,
reg501
Whirlpool... | Answered on Jul 08, 2008
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Whirlpool... | Answered on May 19, 2019
Open the oven door. b) Unplug the microwave oven for 2-seconds and plug it back in. ... The sears manual refers to F6 error as a F6 -Microwave Relay Failure, which would explain why the motor is "humming" The relay is part of the PCB and may require you to get a new PCB
The F6 error indicates a relay on the control has failed.
You can try to unplug the microwave for a few minutes and then try it again. If the error repeats then the control will have to be replaced.
Microwaves are not good do-it-yourself projects and I recommend a technician check and repair this problem.
Microwaves are inherently dangerous to service. Internal capacitors can retain a lethal electrical charge even when the microwave is unplugged. A microwave radiation leakage test must be performed on the unit following any repair.
I recommend calling a service technician to repair this type of problem.
Whirlpool... | Answered on Apr 30, 2019
that could indicate bad door switch and getting it fixed costs around 50.00 here in the us . I paid to have mine done but within 2 weeks it blew up again and when I called the repair place they suggested I replace it as it would cost as much again or more . I replaced it with a much higher priced unit
Whirlpool... | Answered on Apr 09, 2019
DO NOT USE LED BULB
<https://producthelp.whirlpool.com/Cooking/Microwaves/Microwave_Product_Information/Replacing_the_Cooktop_Light_on_an_Over_the_Range_Microwave>
Whirlpool... | Answered on Apr 01, 2019
For most Microwave ovens push the clock button, enter time and clock button again. Some use start instead of second clock push.
Whirlpool... | Answered on Mar 30, 2019
Check the switch that's depressed when you shut the microwave door, it certainly sounds like that's where your problem lies!
Whirlpool... | Answered on Mar 24, 2019
The top door switch must be activated only when the door is closed or the mains fuse will blow everytime. It is a safety device, do not tamper with it! Purchase a replacement latch from a Whirlpool dealer or fleabay or espares etc.
Whirlpool... | Answered on Mar 03, 2019
It may be that you have to modify your space a bit. Perhaps with a smaller micro wave, or remodel the panels in which it is set. Good luck.
Whirlpool... | Answered on Mar 02, 2019
Whirlpool GT4175S Microwave Oven Logo
12 questions posted
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
push button open door not engage
  • Microwave Ovens
