Troubleshooting & Support for
42,276 people viewed this product
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed. 200...
http://www.marleymep.com/en/fahrenheat/products/baseboard-heaters/electric/f2500-series.aspx o...
Hi Edwin, Do you have the unit wired to a double pole 20 amp breaker? It seems that you have only a sin...
Hi! If the circuit breaker is tripping instantly when power is applied to the heater then you have a dea...
Basically each baseboard should be rated for a particular heat output...Watts...which should have an equ...
http://www.marleymep.com/Develop/prod_pdf/2500wiring.pdf i think this is the same parent company
this is a tough call but with 2000 watts in each room there should be more than enough heat .the roo...
same issue years ago. these heaters draw air in from the bottom and push it out the top. so any dir...
at 10kw, that should be about 34130 btu's. With 240 volts, you should be using approximately 41-42 amp...
In my experience soot in the house is (almost) always caused by the burning of candles. Get a CO det...
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wir...
Here is the customer service website to contact them about ordering another knob for your unit. h...
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the the...
If your baseboard heater is rated at 220 VAC and you have wired it to a 120 VAC source then the hea...
Convert the watts to amps or get the amp rating off the device, this will tell you the minimal wire siz...
Have a tip for Fahrenheat Electric Convector Baseboard Heater, 240 Volt?
Hi guys- I need some help. Bought 3 of the above heaters and have two installed from start to...
Please insert details theory of on how an wire baseboard provide 25-28 temperature ? Including...
diagram for chloramox 240 volt baseboard electric heater
