Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner
Problems with Whirlpool Designer ACU109PR Thru-Wall/Window Air...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Whirlpool Designer ACU109PR...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner RSS Feed
View More Results for Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner RSS Feed
Answer
My A/C is set to 66 and comes on and off while the room temp is 80. Is there a quick fix to this... (More)
Find a Manual
Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Designer ACU109PR Thru-Wall/Window Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Find an Expert
Meet our 2649 Air Conditioner Experts
projdoc
#1: projdoc
Rank: GuruGuru
Rating:  94%, 610 votes
Solutions:  1205 (473 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
dmftrucker
Rank: GuruGuru
Rating:  87%, 412 votes
Solutions:  1582 (435 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
roniecon
#3: roniecon
Rank: GuruGuru
Rating:  88%, 655 votes
Solutions:  2185 (393 Votes in the last 30 days)
Experience: A S E certified /35 years experience
avid101
#4: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1159 votes
Solutions:  2486 (363 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
peterrance19
Rank: GuruGuru
Rating:  85%, 64 votes
Solutions:  358 (358 Votes in the last 30 days)
Experience: im a retired rolls royce quality control engineer bourn in the uk now living in spain
justaskjoe
Rank: GuruGuru
Rating:  85%, 2014 votes
Solutions:  3902 (353 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
localwonder
Rank: GuruGuru
Rating:  92%, 2796 votes
Solutions:  4939 (320 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
57 varieties
Rank: GuruGuru
Rating:  88%, 526 votes
Solutions:  1495 (277 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
wracefans24
Rank: GuruGuru
Rating:  87%, 36 votes
Solutions:  265 (265 Votes in the last 30 days)
Experience: Have been working on vehicles since 1973, Have Mopar training,Gm training ,Ford training,
techbuster
#10: techbuster
Rank: GuruGuru
Rating:  89%, 507 votes
Solutions:  1121 (259 Votes in the last 30 days)
Find a Warranty
Specifications for Whirlpool Designer ACU109PR Thru-Wall/Window Air Conditioner
Other Features
Filter
Reusable
ENERGY STAR
With ENERGY STAR??
Swing Louvers
Up / Down · Left / Right
Cooling Operating Range
66 - 88
Key Features
Type
Thru-Wall/Window
Remote Control
With Remote Control
Cooling Capacity
10000 BTU/hr
Energy Efficiency Rating
9.4 EER
Fan Speeds (Cooling)
Electrical Requirements
Voltage
230
Cooling Ampacity
7.6 / 12
Dimensions
Depth
21 in.
Height
14.5 in.
Width
24 in.
Warranty
Warranty
5 Years
Whirlpool Contact Information
Main support number1-800-253-1301
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
