the passenger floorboard on my daughters Saturn Vue is wet. Could it be a plugged air conditioner...
(More)
the passenger floorboard on my daughters Saturn Vue is wet. Could it be a plugged air conditioner drain?
I am attempting to remove the front cover so I can clean my unit. I have already removed the screws,...
(More)
I am attempting to remove the front cover so I can clean my unit. I have already removed the screws, but I can not seem to get the cover off...Is there a trick to it? I don't want to damage anything
The air fan does not work. Can I replace it myself? The compressor turns on but the air does not...
(More)
The air fan does not work. Can I replace it myself? The compressor turns on but the air does not blow. I put my hand in to move the wheel and it will not budge.
i have a whirlpool ac it has leaked from somewhere my floor and everything around it is soaking wet...
(More)
i have a whirlpool ac it has leaked from somewhere my floor and everything around it is soaking wet i don't know how to remove the filter or anything
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part...
written by farfield
Typically if you want a circuit completed when energized you use C (Common) and NO
(normally open). This means that the contact will close when...
written by farfield
A low charge diagnosis for instance can be miss read if the evaporator
is iced up or has any ice in or on it. A sticking thermostat, relay,
or...
written by farfield
What I have always been told is if your 24 volt side burns out check
the high volt side if the hi volt side burns out check the low volt
side. A...
written by farfield
If your wondering how to check out your refrigeration
compressor;
Modern Compressors have two operations that have to work
together just to run....
written by farfield
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date...
written by farfield
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and...
written by bobotfel
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps.
Steps:
1. Add attic insulation....
by wikihow
If your tap water is cool, you can air condition a room with it at minimal cost.
Steps:
1. Obtain a radiator from a small car such as a Honda Civic,...
by wikihow
Steps:
1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing...
by wikihow
Service and Repair, System Maintenance, Advantage Mem... Read More
Service and Repair, System Maintenance, Advantage Member Plans, Replacement & Installation, Guarantees, Air Cleaning and Purification, Duct Sealing, Duct Cleaning, Indoor Air Quality, Heating, Air Conditioning and Indoor Air Quality Products, and Commercial Services for your business.
