20 Most Recent Lasko 4920 Fan Questions & Answers
Order from Lasko.
Lasko Dryers | Answered on Sep 08, 2019
i don't know. please check to ensure the switch or control for oscillate is firmly selected for ""oscillate"". move the control a few times to test.
Lasko Dryers | Answered on Aug 30, 2019
Your picture is kind of dark, so I can't say for certain, but I can speak from experience; the black box might be the problem.
The black box is "potted"- filled with epoxy to absorb heat, protect anything near it, and so you can't/won't try to repair it.
The black box frequently contains a capacitor (and probably a fuse). The capacitor's job is to throw the fan motor's magnetic coils into a microsecond of imbalance, and force the fan to start turning in a particular direction. The capacitor is a very common failure. (Ask anyone that works on the exterior compressor/condensor of a home AC unit)
You can usually prove that's the case by helping a fan to start spinning after the power is applied (just be careful, use a pencil and not a finger, for obvious reasons).
In any case, you should seek to replace the "black box", or more easily, fight your innate tendency to fix everything (I fight with that every day) and just reward yourself with a new fan.
Lasko Dryers | Answered on Jul 01, 2019
A tower fan should not be opened at all. (It’s unsafe to do so, and may damage your fan.) Every two to three weeks, simply use the brush attachment of your vacuum cleaner on the tower fan intake grills to remove lint and dirt, or use a can of compressed air to blow off dust from inner fan blades. That’s it! Your clean tower fan is ready to be plugged back in and get back to keeping your home breezy.
Source:
https://www.lasko.com/periodic-cleaning-keeps-electric-fans-operating-at-their-best/
Lasko Dryers | Answered on Jun 16, 2019
There are screws hidden between the slats on the side of the fan that are not obvious. You will also need to pry the fan apart as it snaps together. On the back by the power cord is a round tab over it. There are some screws under it. They hold the motor to the back assembly. It took about 7 minutes for us to get it apart today because of the screws being hidden on the sides. After a cleaning it won't turn on now.
Lasko Dryers | Answered on May 10, 2019
first, unplug it. then inspect it - find the screws, identify the type screwdriver (phillips - common, torx, less common) remove the screws on one piece at a time, disassemble. clean. (hint, use vacuum cleaner). putting it together again would be the reverse process, although you already know what type screwdriver head you need.
Lasko Dryers | Answered on Apr 12, 2019
Request the diagram directly from Lasko.
Lasko Dryers | Answered on Jan 28, 2019
SORRY BUT WE DO NOT CALL PEOPLE FROM THIS WEBSITE, AND YOU ARE FOOLISH FOR PUTTING YOUR PHONE NUMBER ON THE INTERNET
Lasko Dryers | Answered on Jan 07, 2019
Dryers Logo
2 questions posted
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lasko Dryers
  • Lasko Dryers
Most Popular Question
lasko box fan s not starting up took
  • Dryers
