20 Most Recent
Pelonis Disc Furnace Heater Questions & Answers
Where can I get a
dear sir/madam
please try to search at near of your area on pelonis product,s dealer and then you can buy your air filter there.
hope answer the question
thank you
please vote!
Fan blows, but does not heat. Is there a fuse?
If the fan runs all the time, then it is possible that the high limit control needs to be reset. Some can be reset and some are autmotaic.
Turn Power off
-Turn thermostat up
Turn power back on, if you here the contactor pull in
then your problem is probably a limit switch that
needs to be reset or replaced, thats if you have no heat.
These limit switches can be located inside the main
control panel or located on the outside of the heater
When the fan/heat switch is in the fan position,or
The only thing it can be are the Thermistor, or the Thermostat itself, try first replacing the temperature sensor, the Thermistor, if still no go, then replace the thermostat itself, these are notorious for faulting in this way.
The fan does not turn on but the furnace does
Try turning the fan on manually at the Thermostat by clicking "Fan On"...if thiis turns the fan on...leave it running and you will have heat till a Service Tech can come out....if if doesn't work you will req a Technician to have a look . Likely if the furnace is fairly new either the Relay , Circuit board relay or the motor itself is Defective.
Bill
Can you get replacement discs for pelonis ceramic
I have spent the last 1 1/2 hours going thru several of my catalouges and called a couple of my old suppliers and I can find no source repacement disc. Sorry I could not help you this time.Thank you.
The heater stopped working granted it is old and
I think your heater is probably worn out. I bought one of their units twenty plus years ago and did not do maintaence on it as I should have. It was used a lot as my wife was staying home and besides taking care of our own two she babysat for three or four more. By the time it started giving me trouble I took the back screen off and cleaned lots of dirt and lint out and got another two years out of it. When it quit a small section of the ceramic disc broke off and it was cost prohibitive to buy repair parts.
This is a very good unit but now it's jist less expensive to buy a new radiant heater every 3-4 years. Sorry I know that's not much help. Thank you.
Makes a noise when turned on.. sounds like fan or
I would make sure the heater is unplugged then remove backscreen and foam filter. Carefully clean firter with warm water and alittle dish soap. Rinse thouroughly and air dry it. I would clean any hair lint or other debris from fan blades,motor and heating elements. You can use a tooth brush to clean heating elements.You can also use a drop or two of light grade machine oil or WD-40 on blower shaft where it enters the motor. Wipe off any excess oil and when you're sure filter is dry reassemble and try it. Hope this helps you.Thanks
Pelonis LT101A/ B2-IVA
Pelonis heaters generally have safety devices built in to them for if they fall over and such. This model may have other safety devices, I would check it out in the manual. If its completely dead in the camper, there could be a problem with the outlet in the camper.
Fan squeals slightly while running
Probably the fan bushings need a drop of 3 in 1 type oil. you will have to take the heater apart to gain access. Only use one drop as excess oil will cause odor problems and could also be a fire hazard.
