20 Most Recent Grundig G4000A FM/AM Radio Questions & Answers
You have buttons to press to change the modulation.
FM covers regular FM band: 76 MHz (Japan) to 108 MHz and the higher frequency ones used for Air and Weather.
AM covers the Long waves (in Europe), the regular AM band (520 kHz-1700 kHz), and the Short wave bands 2MHz 30 MHz
It seems that you can tune the frequency in by direct entry with the number keys.
I do not see the image of the face of the radio but from my experience with many Grundig/Eton you should have two buttons with arrows (left A and Right Arrow) or two buttons with + and Minus (not the volume buttons). If you are in SW, pressing one of the buttons changes the tuning to the adjacent Meter band.
Grundig G4000A... | Answered on Mar 19, 2015
HOW TO SET THE SLEEP TIMER
Press the
SLEEP
button over and over. Each press
changes the amount of time the radio will play before
shutting off automatically, 60 through 0 minutes.
To make the radio work without a timer, try pressing the ON button longer than you usually do.
Grundig G4000A... | Answered on Dec 04, 2013
Here is the link to eton corp for your manual
Hope it helps.
Grundig G4000A... | Answered on Aug 01, 2013
its a Windows Operating System based Mobile and do not have FM Radio.
Grundig G4000A... | Answered on Mar 02, 2011
I was able to track down a copy of the manual for you. If you click on the link below:
http://www.etoncorp.com/upload/contents/307/G4000A_manual_lowres.pdf
(you can either click on the link directly, which will open a copy of the manual in a new window, or right-click on it and choose Save As) you can download a copy of the manual. Page 3 of the manual explains an important setup step for using the radio in North America. Instructions for setting the clock and using the alarm feature are on page 14.Hopefully this will give you all of the information that you need. If not please let me know and I can provide you with further assistance.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Grundig G4000A... | Answered on Feb 24, 2011
http://www.etoncorp.com/product_card/?p_ProductDbId=6294
At this address you will be able to download manual and specs for Grundig radio G4000A
Grundig G4000A... | Answered on Feb 11, 2011
If the internal antenna is broken that means the ferrite bar is broken,that does imply that the wiring around it is cut. If the two parts are not removed, the antenna may still be able to perform correctly (just as two magnets put end to end). You can try to put it in the vicinity of another radio to see if there is any resonance effect.
Hope it helps.
Grundig G4000A... | Answered on Nov 09, 2009
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
The wires that feed the speaker are usually attached on the back of the conical part of the speaker. They are usually soldered on two terminals.
Hope it helps.
Yes it will if you know the frequencies and the broadcast times of the radio you want. During the night the best broadcast bands are the longer wavelengths.
49 m from 6390 kHz and up
41 m from 7600 kHz and up
31 m from 9200 kHz and up
25 m from 12121 kHz and up
During the day Use the shorter wavelengths 11m, 16m, 21/22 m
Unfold the whip antenna, or use the wire antenna if you have one.
Reception is affected by the electrical charge denisty of the ionosphere. It depends on the solar activity (sun spot flares and such activities).
You will hear Radio China international all over the spectrum, Deutch Welle, Radio Canada International, Radio Havana, and a plethora of Religious brodcasts. If like me you miss Radio Moscow, it is now called Goloss Rossya (The voice of Russia). Don't get upset, I was joking.
Good listening.
Grundig G4000A... | Answered on Nov 06, 2009
At this address you will be able to download manual and specs for Grundig radio G4000A.
Grundig G4000A... | Answered on Sep 11, 2009
This link will take you to the Grundig/Eton site where you can download and print the complete manual for your radio:
Bill B.
San Antonio
Grundig G4000A... | Answered on May 16, 2009
Once you turn the unit on, the battery indicator should disappear. Make sure the batteries are inserted correctly. With six AAs, I've put them in backwards on more than one occasion.
Hope this helps.
Grundig G4000A... | Answered on Jan 11, 2009
Grundig G4000A FM/AM Radio Logo
26 questions posted
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Sheldon Dedek
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Grundig Audio Players & Recorders
Most Popular Question
old manuals
  • Audio Players & Recorders
