FixYa.com
Uniflame 153100 Open Flame Patio Heater
All Products > Uniflame > Heaters
Problems with Uniflame 153100 Open Flame Patio Heater?
Search inside Uniflame 153100 Open Flame Patio Heater Knowledgebase
Troubleshooting and Support
Solved Problems for Uniflame 153100 Open Flame Patio Heater RSS Feed Post a New Problem
I use several small space heaters...
I use several small space heaters annually, as well as a couple of fans and have to replace these almost annually...
1 Solution
I just installed a gas heater and I am...
I just installed a gas heater and I am concerned that it might not be big enough to heat my pool effectively. It seems...
1 Solution
Furnace will not come on, need heat!
The Furnace worked fine last year and now it does not? I am sure that it is something simple but I have no idea how to...
1 Solution
Pilot light goes out!
Hello, I own a procom heater Serial # 3640534 QJ002 The pilot light has a bit of a yellow flame. Anyway,...
1 Solution
Cadet heater quite working
I've got a Cadet C122 wall heater that quite working. There's 240V to the heater and continuity across the reset switch....
1 Solution
Pilot light will not stay on when egnition...
vokera excell 80 boiler. Pilot light will not stay on when egnition switched is released! Pilot light keeps going off...
1 Solution
reddy heater
getting fuel and spark but won't ignite
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypePatio
Power SourceGas
Heating ElementOpen Flame
Safety Features
Safety Features100% Burner Shut-Off, Tilt Switch, CSA/CE Approved
Power
BTU40,000 BTU
Dimensions
Depth26.5 in.
Height91 in.
Width26.5 in.
Warranty
Warranty1 Year
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
