20 Most Recent
Maxtor DiamondMax 60 (33073U4) 30.7 GB Hard Drive Questions & Answers
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
11/20/2013 3:22:46 AM •
Maxtor...
Answered
on Nov 20, 2013
Hard Disk Drive Problem
In windows right click on my computer icon/manage/disk management. You should see that drive in there. all you have to do is right click on it and format it and your done. Now Windows will see.
but make sure that you lost all the data from that HDD.
Post back to me if you need more help.
Good Luck!!
Thanks
7/8/2009 5:27:12 AM •
Maxtor...
Answered
on Jul 08, 2009
Hard drive was freezing up .i have already replaced and reloaded
On the back of the hdd you will see a row of little pins in groups of 2 vertically. It will be marked either right above the pins or on the top of the hdd above the pins, ma, sl, cs. The setting for slave is sl. Put the plastic jumper cap on those 2 pins & it is set for slave. Hope this helps & please remember to rate my answer. Thanks.
1/22/2009 9:04:26 PM •
Maxtor...
Answered
on Jan 22, 2009
Hard drive not readable
You can try it on another computer but I expect you will need data recovery help. I can suggest http://FreeDataRecovery.us
8/24/2012 8:26:54 PM •
Maxtor...
Answered
on Aug 24, 2012
6E040lo error code CA699178
are you sure this is the error code ca699178 ?click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope this helps you
3/24/2012 6:18:11 PM •
Maxtor...
Answered
on Mar 24, 2012
Hard drive clicking
your las hope is to replace the Pcb Controller with a working and exact same one ,
2/9/2012 1:45:01 AM •
Maxtor...
Answered
on Feb 09, 2012
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
