20 Most Recent
Maxtor Ultra ATA/133 PCI Adapter Card (999812) IDE Controller Questions & Answers
Maxtor ultra 133 raid drivers windows 7
Driver is for Vista but should hopefully for Windows 7. This is a legacy card no further driverswill be added past Vista.http://firstweb.promise.com/upload/Support/Driver/Ultra133%20TX2%20windows%202.1.0.3%20logo%20driver.rar
I have a 1999 Gateway computer w/Maxtor Ultra
hello ellesmere28!
everything is possible... anyway it sounds like you have SCSI devices, for those you need a SCSI controller those mostly also available for PCI socket. please count pins and let me know for further assistance. post here under your topic
regards
Ultra ata 133 ide controller........i installed
if u cant locate the drivers name, try using unix base(linux) live cd's, like knoppix for example, they usally detect all the drivers u have in minutes and even gives u all the names and serial numbers, then u can download them.
Hello, I have a PCI
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
