20 Most Recent
Pioneer Premier DEH-P580MP CD Player Questions & Answers
The radio is muted. cannot
try disconnecting the power from it by either the unhooking the battery or pulling the radio fuse. Then it should reset
How to change color display
to change these types of setting you must turn off the stereo (hold off) then PRESS & HOLD the menu button (mines a different model but the menu button is pressing the volume knob )
Speaker wire specs for front and rear on the
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
hopes this helps
pls rate
Pioneer DEH-P580MP
radio muted, can not
there is a short somewhere. check your speaker wire on the stereo to make sure none of them are shorted. also, check the speakers to make sure none of the speakers themselves are short (shorted voice coil). disconnect one speaker at-a-time to find the shorted speaker.
Can not get stereo in aux mode
it sounds like they've disconnected the battery on you and reset the unit.with the unit powered up (key on) If you turn off the radio by holding the source button then press and hold the function button (the round one that adjusts the volume) it takes a few seconds.......Note if you turn or move it up down or to either side it won't work. the menu will come up to change various settings including turning on the aux function.
Hope this helps!
STILL HAVIN TROUBLE
"WHICH COLOR WIRE SAVE THE SETTING" - yellow must be connected to an always on B+12 such as the positive terminal of the battery and
red to a switched B+12 such as the ACC terminal of the IGN switch
orange goes to the park/instrument light
Orange = Illumination
Some vehicles have an illumination signal that tells the stereo when your headlights are turned on so that it can dim the display (to help keep from being blinded by overly bright stereo displays at night). If you don't have that signal, don't connect the stereo wire to anything.
