20 Most Recent
Freecom Xs External Usb Hard Drive 2tb Questions & Answers
Broken usb
several things and solutions you can do.if it's just an external hdd you can rip it to bits and take the drive out and use it as an internal drive, or take it to pieces and get an external hdd caddy for the size of the drive (3.5" or 2.5") they are cheap enough to buy.
10/21/2013 10:02:39 AM •
Freecom...
Answered
on Oct 21, 2013
I have an old Freecom external hard drive
If you checked with alternative cables, and on another computer, then your left with one option only. Removing the HDD from the casing.If the HDD is still working but the case is not. You need to remove it from the case and connect it to a computer directly.If once removed it is still not working you can try to put it in a sealed plastic bag and in a freezer for a day, the quickly try to connect it to a computer.If it is still not working you only other solution is to send it to a specialized company that will open it and read the data directly from the plates. This is done in a sealed environment (think high tech dust free rooms with people coverd in white)Thus it is expensive and usefull only id the data has a real value to you.
10/20/2013 7:38:18 PM •
Freecom...
Answered
on Oct 20, 2013
