I have a Pioneer DV-383-S DVD player. When I switch on the player the player goes to a Regional...
(More)
I have a Pioneer DV-383-S DVD player. When I switch on the player the player goes to a Regional Settings Screen where it prompts me to select a region code from 1-6. (Player?s Region Settings) <1> : Region <2> : Region <3> : Region <4> : Region <5> : Region <6> : Region Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. It does not proceed beyond that screen. I am unable to go to any menu. I have tried resetting the player by pressing the STOP button and then the STANDBY button to switch it on, changing from NTSC>PAL>AUTO by pressing the FORWARD button and the STANDBY button. Nothing is working. Anyone else using this player and facing a similar issue..???? My E-mail ID is sanjay.jagtap1386@rediffmail.com
I have a DV-383S model pioneer player and it was working fine from last two years and from last one...
(More)
I have a DV-383S model pioneer player and it was working fine from last two years and from last one week it is asking for region settings when i switch it on.I am not able to operate any buttons on remote control except power on/off,open/close,home menu. My E-mail ID is sanjay.jagtap1386@rediffmail.com thanks in advance for your support
i donot have and irda device and donot have a cd to unlock the parental lock and how to unlock the...
(More)
i donot have and irda device and donot have a cd to unlock the parental lock and how to unlock the region
hi, my Pioneer DV-383S DVD Player shows region problem.only off/on & open close buttons comands...
(More)
hi, my Pioneer DV-383S DVD Player shows region problem.only off/on & open close buttons comands work & none of the other comands r working. please help me,i will be thank ful to u for ur support.
every year the reginal settings shows up and I am tied of paying to get it fixed up. the only thing...
(More)
every year the reginal settings shows up and I am tied of paying to get it fixed up. the only thing I can i can use is the power button. please advise me were i could by the RS-232 Cable or using pioneer service remote control for my model to fix my proble or do I need to do something else.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
