20 Most Recent Toshiba HDTC610XK3B1 Canvio 3.0 Portable Hard Drive HDTC610XK3B1 Questions & Answers
I have the same problem. I can read/see the drive with my old computer but not the new one. I believe it's because the drivers for this are not current. Toshiba doesn't seem to have/provide current drivers for Win8. The drive has drivers for Vista and 7, but not 8. Does anyone know whether there are Win 8 drivers? Hard to believe Toshiba wouldn't provide that since 8 was out only a year after this drive was made.
Toshiba... | Answered on Aug 31, 2014
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Toshiba Canvio... | Answered on Jan 29, 2016
The "drive not ready" error can have several causes.
Commonly, ownership or access permissions have not been set up properly for the files, the folders, or the entire disk, and this can be reported erroneously as a "not ready" state. VLC would have nothing to do with this, unless it was during its installation that the permissions accidentally got whacked.
You didn't say which file systems are involved, and that can make a difference.
There is always the possibility that the drive and the computer really cannot communicate with each other. If you are lucky, it is just a bad cable, otherwise it is the controller or the drive itself that actually is at fault.
Toshiba Canvio... | Answered on Dec 09, 2014
You are talking about accessing a Hard Drive via IP Network Address. Very difficult to troubleshoot via this method as the Network protocol interfears. Try plugging the drive in via USB or FireWire etc.
On A hardwired port it is easier to access the drive & copy it's contents to a backup device before formatting & testing the drive and adjusting the IP address to you preferred settings.
The drive can also (probably) be taken out of it's case box and plugged into another case with a USB port on the back or directly into it's ATA or SATA port on the actual drive. This is the preferred way to back up as it's much faster than Network or USB access for large file transfers. You can buy external empty cases. eg. See OWC. Other World Computing website.
Toshiba Canvio... | Answered on Nov 01, 2014
More than likely, this is some sort of fault in the logic of the external enclosure. The solid light indicates that the drive is powered and is awaiting access while the blinking light means that it is busy working. If you are unable to get the drive to do anything (whether reading data from the drive or storing data to the drive), then I would guess that it is time to see whether you still have warranty coverage on the drive and, if so, get it replaced under warranty.
In my experience, I have found that Toshiba drives are very unreliable and therefore would recommend that you replace it with a Seagate if this drive no longer has any warranty coverage. Of all the drive manufacturers, I have found Seagate drives to be the most stable and reliable. Others may recommend Western Digital but I replace failed Western Digital drives on a constant basis in my computer repair business each and every week while Seagates keep on going. I base my recommendation on being in business now for over 25 years.
Toshiba Canvio... | Answered on Oct 19, 2014
Unless you used the "Move" command, the data should have only been copied off the Canvio, so you should be able to copy (or move) it to another computer as well if you so wish.
Does not need a driver.
COMPATIBILITY:
  • Formatted NTFS for Windows XP, Windows Vista, Windows 7 or Windows 8
  • Requires reformatting for Mac OS X Tiger, Leopard, Snow Leopard or Lion
  • Available USB 3.0 or USB 2.0 port
  • USB 3.0 port required for high speed transfers
Toshiba Canvio... | Answered on Jun 26, 2014
Please test it by cutting a data file and pasting it in this hard drive. If it is success, then probably the type of your data is different and it is not freely moveable, or you it is possible that you tried to move the files to the same folder (it happens when the user opens many Windows Explorer/File Manager).
Toshiba Canvio... | Answered on Mar 03, 2014
with the help of first mouse button you should click , then keep it on, on the click position then release the button where you want to drag it
Toshiba Canvio... | Answered on Mar 04, 2013
This happens when the blue channel of the VGA cable doesn't work. This can be by an internal defect or by a defective cable. Since you changed the cable already, its the connector.
Toshiba... | Answered Yesterday
It could be a corrupt file or a faulty hdd. Press the F8 key when you power it up and choose last good boot option. If it won't boot, purchase an OS disk and boot from the DVD ROM. If it won't load purchase a new hdd and install the new OS.
Toshiba HDTC610XK3B1 Canvio 3.0 Portable Hard Drive HDTC610XK3B1 Logo
Popular Tags
7 questions posted
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Canvio Toshiba
  • Canvio Toshiba
Most Popular Question
toshiba external hard drive not being
  • Computers & Internet
