20 Most Recent AEG B2100-4 Electric Single Oven Questions & Answers
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
AEG B2100-4... | Answered on Dec 04, 2012
The large oven door pull's off , and can also be pused back on the same way , if holding the door about 12" from closing pulled towards you to remove or push down to put back on if you pull it off the hinges it may take two to put it back on again
AEG B2100-4... | Answered on Dec 07, 2011
Sharon First turn off power on this oven or unplug it if you where useing the oven then that element went bad if it was the broiler then it is that one , very easy to fix and it is cheep also, with a flash light look at the elment for damage don't touch it unless the power is off , get back to me with the information like make model serial number and i will locate the element for you and you can buy it at the place if find it for you . good luck Frank
If there are no other connection ports, and you only disconnected the three, it is possible that (if this is an aftermarket wiring harness) the third was put in for similar units with an additional option of some sort, and is not needed for your model. However, I highly suggest referring back to the place of purchase, as well as the manufacturer to find out for sure before plugging the unit in and using it.
Please let me know if you need further assistance,
carsandcomps,
Guru, Premium Expert, Phone Support (Chat) @ Fixya.com
AEG B2100-4... | Answered on Jun 19, 2011
Sounds like it is overheating, check to see if the external cooling fan is working o/k, because if it is not, the oven will overheat, and cause the safety stat to stop the oven working.
AEG B2100-4... | Answered on Nov 24, 2010
make sure you have set the time of day. come back if this is no use
AEG B2100-4... | Answered on Nov 10, 2010
I suspect it is the oven element causing the problem, as it gets hotter, the insulation resistance is probably breaking down, and causing the trip to operate.
AEG B2100-4... | Answered on Oct 31, 2010
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
AEG B2100-4... | Answered on Jul 24, 2010
The wires to the element shorted out by not being connected and to close to the metal cavity. This should have tripped your circuit breaker. Before resetting reconnect the old element or put in the new one then turn on power. If nothing illuminates you will need to replace the main control. This is easy to replace but not inexpensive. You can get diagrams and illustrations at www.appliancehelponline.com All parts come with installation instructions.
AEG B2100-4... | Answered on May 12, 2010
Does the thermostat click and the light go off and on when you turn it up and down if so it is mechanically working.
Fan will run irrespective of element working
Either the element has failed or the connections to the element
Both require you to take the back off the machine to check them out
AEG B2100-4... | Answered on Jan 26, 2010
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
AEG B2100-4... | Answered on Aug 12, 2009
AEG B2100-4 Electric Single Oven Logo
50 questions posted
Top AEG Ovens Experts
Steve Allison
Steve Allison
Sal De
Jason Harris
Jason Harris
Are you an AEG Oven Expert? Answer questions, earn points and help others
View Most Popular
AEG Ovens
  • AEG Ovens
Most Popular Question
oven gone bang
  • Ovens
