20 Most Recent Maytag MER5875RAS Stainless Steel Electric Kitchen Range Questions & Answers
2answers
Maytag MER5875RAS baking element will not heat up
There are parts and diagrams for that unit here: http://www.appliancepartspros.com/03-control-panel-parts-for-maytag-mer5875ras.html The switches on the panel are pricey though.
11/12/2017 9:21:29 PM • Maytag... • Answered on Nov 12, 2017
0answers
Maytag mer5875rcs the electronic ignitor does not work
If all the other burners are igniting then you need a new switch if they all don't light on their own then you need a spark module
11/10/2013 2:25:04 PM • Maytag... • Answered on Nov 10, 2013
How do I open the top of a Maytag MER5875RAS
The following link explains how to access a surface burner on an electric range and replace (if required):
http://www.fixya.com/support/r3692628-surface_burner_replacement_electric
Replacement parts (if reqiuired) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
5/16/2010 7:41:18 PM • Maytag... • Answered on May 16, 2010
Stove ignitor does not light burner. How to fix ?
This may sound silly and I know your stove is gas, but is your stove plugged into a power outlet on the wall? Some older stoves had the igniters powered from a wall socket so had to be 'plugged in' and others are powered by replaceable batteries, (AA's or AAA's), with the pack being mounted low down on the front, near one of the front feet. If it is a battery type try changing the battery for a new one. Sometimes the fix is that easy.
10/7/2023 4:48:47 PM • Maytag Kitchen... • Answered on Oct 07, 2023
My maytag gemini oven keypad (numbers only) stopped working.
If the keypad on your Maytag Gemini oven (numbers only) has stopped working, there are a few troubleshooting steps you can try:
  1. Power cycle the oven: Turn off the oven by unplugging it from the power source or by switching off the circuit breaker. Leave it powered off for a few minutes, and then plug it back in or switch the circuit breaker back on. This can sometimes reset the keypad and resolve temporary issues.
  2. Check for physical damage: Inspect the keypad for any physical damage, such as cracks or signs of wear. If you notice any damage, it may be causing the keypad malfunction. In such cases, the keypad might need to be replaced.
  3. Clean the keypad: Over time, dirt, grease, or food particles can accumulate on the keypad, which can interfere with its functioning. Use a soft, damp cloth to gently clean the keypad. Avoid using harsh chemicals or excessive moisture that could damage the keypad.
  4. Test the oven's other functions: Check if other functions of the oven are working properly, such as the temperature controls and other buttons. If only the numeric keypad is affected, it could indicate a specific issue with that part of the keypad or the underlying circuitry.
  5. Contact Maytag customer support: If the above steps do not resolve the issue, it is advisable to contact Maytag customer support or schedule a service appointment with a qualified technician. They will be able to provide further guidance and assistance in diagnosing and fixing the problem.
6/28/2023 5:00:31 AM • Maytag Kitchen... • Answered on Jun 28, 2023
I changed my Maytag over to lp and the oven and broiler don't get propane to it it glows but no flam what's wrong
If you've converted your Maytag oven to LP (propane) and you're experiencing issues with the oven and broiler not receiving propane and not producing a flame, there could be a few possible causes:
  1. Gas supply: Ensure that the propane supply to the oven is turned on and the gas valve is fully open. Check that the propane tank is properly connected and that there is sufficient propane in the tank. If the tank is low or empty, it may need to be refilled.
  2. Incorrect conversion: Double-check that the conversion from natural gas to LP was done correctly. Verify that the conversion orifices have been installed in the correct locations and that the air adjustment shutters or plates have been adjusted according to the manufacturer's instructions. Improper conversion can result in inadequate gas flow and a lack of flame.
  3. Clogged orifices: It's possible that the orifices, which control the flow of gas, have become clogged with debris or residue during the conversion process. Clean the orifices using a small brush or a compressed air canister specifically designed for cleaning gas orifices.
  4. Gas pressure: LP gas operates at a higher pressure than natural gas. Ensure that the pressure regulator on the oven has been adjusted or replaced to accommodate LP gas. If the regulator is not properly set for LP gas, it may not deliver the correct pressure for proper combustion.
  5. Faulty ignition system: If the oven and broiler are glowing but not producing a flame, there may be an issue with the ignition system. Check the igniter for any signs of damage or wear. A faulty igniter may not generate enough heat to ignite the propane. Consider replacing the igniter if necessary.
If you've checked these potential issues and the problem persists, it may be best to contact a qualified appliance technician or the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or arrange for a service visit to diagnose and resolve the issue with your Maytag oven.
6/18/2023 7:38:29 AM • Maytag Kitchen... • Answered on Jun 18, 2023
Is it normal for the air fryer fan in my Maytag stove to keep turning on and off every few seconds?
Question edited for clarity (typos, fun to fan, of to off). Maytag doesn't mention, but BestBuy says it is normal.
Using the Air Fry Feature
Maytag https://producthelp.maytag.com > Product_Info > Usin... Jun 29, 2022 - Using the Air Fry Feature on Maytag Range or Oven Convection fans will circulate hot air very quickly around the surface of the food, which ...
Just used my Whirlpool convection oven air fryer - Q&A
Best Buy https://www.bestbuy.com > site > questions > question Dec 6, 2021 - Hello, this is a normal operation for the fan to turn on and off to help with air circulation. We hope this helps. ... Sorry, there was a problem.
3/29/2023 3:05:49 PM • Maytag Kitchen... • Answered on Mar 29, 2023
2answers
Maytag Gemini, double oven electric. Replaced bottom element, replaced thermal sensor and tested power. It still won't heat up. WHY?
There are several potential reasons why your Maytag Gemini double oven electric range is still not heating up after replacing the bottom element and thermal sensor and testing the power. Some possibilities include:
  1. The wiring or control board may be faulty and preventing the oven from heating up.
  2. The upper heating element or broil element may also be faulty and need to be replaced.
  3. The oven may not be calibrated properly, which could cause it to not heat up correctly.
  4. There may be a problem with the oven's door latch or switch, which could prevent it from heating up.
2/14/2023 5:03:34 AM • Maytag Kitchen... • Answered on Feb 14, 2023
Maytag precision touch control 800 electric slide-in smoothtop: the Inner element of triple burner stopped working. How to fix it?
The first step to fixing the inner element of a Maytag Precision Touch Control 800 Electric Slide-In Smoothtop is to check the power supply for the range. Make sure all connections are secure and that the outlet is working properly. If the power supply is fine, then you may need to replace the inner element on your range. It would be advisable to consult the manual
1/30/2023 5:34:28 PM • Maytag Kitchen... • Answered on Jan 30, 2023
2answers
I got a Maytag Gemini range and the front left burner smells like it's leaking gas when the knobs are all off
If you smell gas coming from your Maytag Gemini range, it is important to take immediate action. Gas leaks can be dangerous and can cause fires or explosions. Here are a few steps you should take:
  1. Turn off the gas supply to the range: Locate the gas shut-off valve for the range and turn it to the "off" position. This will stop the flow of gas to the appliance.
  2. Open windows and ventilate the area: Open windows and doors to allow fresh air to circulate. This will help dissipate the gas fumes.
  3. Do not use any electrical switches, appliances, or light fixtures: The sparks from these devices could potentially ignite the gas.
  4. Leave the house: If you suspect a gas leak, it is best to evacuate the house and go to a safe location.
  5. Call for professional help: Contact a gas company or a licensed appliance repair technician to repair the gas leak and check for any other issues with the appliance.
1/8/2023 3:39:53 PM • Maytag Kitchen... • Answered on Jan 08, 2023
Seeking salvage 7601P428-60 timer control for Maytag gas range model 6498VVV. Sourcing suggestions?
It seems that the 7601P428-60 timer control is a discontinued part and may no longer be available from Maytag or other retailers. Your best bet for finding this part would be to check with appliance repair shops in your area, as they may have used or refurbished parts available. You could also try searching online marketplaces such as eBay or Etsy, as well as appliance forums or Facebook groups where people sell or trade appliance parts. Keep in mind that these sources may not always have the part in stock, and it may take some time and effort to find a seller who has the part you need.
1/6/2023 8:05:56 PM • Maytag Kitchen... • Answered on Jan 06, 2023
Sab bath error code for my maytag oven MGRH865QDW1
Hi and welcome to FixYa, I am Kelly.
Press and hold the clock button for at least 3 seconds to stop the sabbath mode. This should bring it back to normal operation. If not just respond here and I can walk you through the lengthy diagnostic cycle to clear it.
Thanks for choosing FixYa,
Kelly
1/5/2023 10:52:30 AM • Maytag Kitchen... • Answered on Jan 05, 2023
2answers
My Maytag MER5755QAS oven won't heat up. My broiler will not work at all. I choose Bake, set to 350 degrees & it reverts back to 100 degrees and just stays there. My range top works perfectly.
A Maytag oven not heating at all may be due to a blown thermal oven fuse. Your oven's thermal fuse is a protective feature that trips when the oven overheats
11/20/2022 4:04:47 PM • Maytag Kitchen... • Answered on Nov 20, 2022
My Maytag MIR8890AS cook top won't recognize I have a pan on the burner?
Phone the 'Certified Technician' and ask if they service Maytag stoves, then ask them how much they charge, and then finally ask them what the warranty is on their work. Then tell them to come back and fix it. The reviews are very mixed and there are lots if dissatisfied people. https://www.amazon.com/Maytag-Stainless-Steel-Electric-Range/product-reviews/B0075GB2SQ The best thing you can do is turn it off at the breaker when you go to bed tonight in the hopes of a reset. No one else has encountered your specific issue. The other thing with induction tops is that they must be perfectly clean. https://www.google.com/search?q=Maytag+MIR8890AS+induction+cook+top+won%27t+recognize+I+have+a+pan+on+the+burner ..
6/16/2022 1:28:14 AM • Maytag Kitchen... • Answered on Jun 16, 2022
Maytag MER5875RAS Stainless Steel Electric Kitchen Range Logo
13 questions posted
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
maytag mer5875ras baking element will
  • Kitchen Ranges
