Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
Maytag (MFI2568AEW) Bottom Freezer French Door RefrigeratorTroubleshooting & Support
Problems & Solutions
  • If you don't mind following with me on this I can help you locate the problem even if it requires me calling Maytag. I am a Whirlpool...
    • ldjouett
    • Feb 11, 2011
    • 142 Views
    • 1 Solution
  • In a Home the recommended level (front higher to back lower) is 1/4" (Right to Left - level) Never less than in order to allow door to...
    • gmavro
    • Nov 2, 2007
    • 3163 Views
    • 2 Solutions
  • You don't need a plumber. The filter is located inside the fresh food section, in top-right corner. There is an elongated cover with a...
  • We have parts for you! Email or call me and I will get the correct filter to you right away. 9728592929. I will need your address and it...
  • 1) If the icemaker doesn't make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is...
    • lhseidel
    • Aug 26, 2009
    • 300 Views
    • 1 Solution
  • check this site they may have what you need appliancefactoryparts.com
  • Hi, You can use a hair dryer to thaw the inlet tube out. Some mofeld will aloow you to remove the inlet tube from behind the refrigerator....
    • ginphx
    • Jun 14, 2009
    • 397 Views
    • 1 Solution
  • Call Maytag. They are aware of the problem. When I called them last year, they sent me a new control board for free, but they didn't...
    • lennylac
    • Aug 22, 2008
    • 957 Views
    • 1 Solution
  • If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an...
  • the filter for this unit is located in teh upper right hand corner of the refrig ceiling. there is a thumb latch on the cover release teh...
  • As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it. This is...
  • I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to...
    • lwaz02
    • Jan 27, 2008
    • 112 Views
    • 1 Solution
  • Solution #2 posted on Jan 06, 2008 Navycpowif Rank: Apprentice Rating: 100%, 1 votes This is NavyCPOwif- As you read above I have a crazy...
    • padaniel
    • Jan 24, 2008
    • 127 Views
    • 1 Solution
  • I had the same problem, fixed it myself with <$20 in parts from Radio Shack ( <$5 if you have soldering equipment, or know someone who...
  • Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and...
    • billy97
    • Aug 13, 2007
    • 157 Views
    • 1 Solution
See all Maytag (MFI2568AEW) Bottom Freezer French Door Solutions
Tips & How Tos
Do you have any good tips or tricks? - Write a Tip!
More
Unsolved Problems
See all Maytag (MFI2568AEW) Bottom Freezer French Door Problems
Manuals & Guides
Top
Do you have a manual for Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator? - Upload it to FixYa!
Specifications
Top
Key Features
  • Full Product Name:
  • Type:
    Bottom Freezer
  • Type:
    French Door
  • Number of Motors:
    1 Motor
  • Total Volume:
    25 cu. ft.
  • Ice Maker:
    With Ice Maker
  • Installation:
    Free-Standing
  • Total Number of Shelves:
Fresh Food Compartment
  • Fresh Food Shelves / Bins:
    Gallon Storage
    Meat Pan
    Dairy Center
    Spill Proof Shelves
  • Shelf Material:
    Glass
  • Door Opens:
    Opens to Left and Right
  • Light:
    Yes
Ice Maker
  • Dispenser:
    Water
  • Dispenser:
    With Water Filter
  • Dispenser:
    Ice
Convenience
  • Exterior Color:
    White
  • Defrost:
    Automatic Defrost
Energy
  • Annual Energy Consumption:
    581 kWHrs
  • Energy Efficiency:
    Energy Star Compliant
Dimensions
  • Overall Depth:
    35.25 in.
  • Overall Height:
    70.13 in.
  • Overall Width:
    35.63 in.
Warranty
  • Warranty:
    1 Year Parts and Labor
What's your problem?
