I need to increase the screen resolution of the Akai LCT 2060 when in PC mode, while attached to my...
(More)
I need to increase the screen resolution of the Akai LCT 2060 when in PC mode, while attached to my Dell Inspiron 700m laptop. It currently won't let me adjust resolution to anything more than 800x600... please help!
i've taken it to work to use as a monitor (as it no longer works as a TV since the unit that the...
(More)
i've taken it to work to use as a monitor (as it no longer works as a TV since the unit that the cable signal feeds thru seems to be shot)... but the resolution of the screen is WAY too low... is there an upgrade or new driver or something that i can look for to get the screen resolution to a manageable size?
TV was turning on for a few seconds, then turning off. Leaving it unplugged for a long while it...
(More)
TV was turning on for a few seconds, then turning off. Leaving it unplugged for a long while it again would turn on for a few seconds. Now it won't turn on at all. Could this be the power adapter? Or is it time to junk the tv?
my akai 42" plasma tv just stop working. I was not in the room at the time so I don't know what...
(More)
my akai 42" plasma tv just stop working. I was not in the room at the time so I don't know what happen.The power light comes on but no picture or sound. It is about 6 years old . what can I do Thanks grady
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
