20 Most Recent
Clarion APX480M Car Audio Amplifier Questions & Answers
My Clarion APX480M marine amp cuts out at random
try to unplug each speaker one by one while playing it. There can be a defective speaker that grounds out at the speaker terminal or internally causing the amp to go into protection causing all the speakers to go out.
Clarion APX480M amp
This sounds like a signal problem. Make sure that all of your signal cables are plugged in fully. If all are, you need to check for coninuity between the shield ground of the head unit's RCA jacks and the case of the head unit. With no RCAs plugged into the head unit, you should read ~0 ohms between the shield of the RCA jacks and the case of the head unit.
P code for a Clarion cx501
If the radio is a factory radio, the code to unlock it should be on a business card size piece of paper with the owners manual and warranty booklet. The card will say radio code and have a six digit number.
Nissan PP2449H wiring diagram.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/BLUE (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls NO
Speed Cntrl NO
This listing is for a 2004 Frontier
__________________
