20 Most Recent Solis Maestro G385 Electric Burr Grinder Questions & Answers
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Solis Maestro... | Answered on Jul 20, 2010
Hi
Try Baratza 877-701-2021
Solis Maestro... | Answered on May 11, 2010
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Solis Maestro... | Answered on Jan 13, 2010
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Solis Maestro... | Answered on May 26, 2009
Hi
Sounds like you may have broken off the adjustment tabs on the outer ring. Contact Baratza for help.
Hi
Remove bean hopper
Try cleaning the grinding ring with a thin pointed tool.
Solis Maestro... | Answered on Mar 01, 2009
Solis Maestro G385 Electric Burr Grinder Logo
11 questions posted
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Pierre Laplante
Ekse
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Solis Coffee Makers & Espresso...
  • Solis Coffee Makers & Espresso...
Most Popular Question
when grinding blade will not
  • Coffee Makers & Espresso Machines
